Stereo draining battery need advice
I have had a reoccuring problem with an electrical short draining the battery on my 911. Using an ampmeter it appears the drain was coming from the CD player. With the ignition switch off this radio was drawing 310 millamps continious. I disconnected it and amp draw went down to 9.9 millamps(clock). I've installed a new CD player and tested standby amp draw again. It is now 145 milliamps. Is this too high or more sound more typical of a CD player?Will this drain the battery again? Thanks for all the previous help. Bill
To high for me.. I'm not an audio pro. I look for a max drain about 60ma for everything with the engine off..........Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
By an old stereo system that doesn't have an electronic clock or use electronic memory for stations recall. Any one with an old eight track forsale?
8 track, what the heck is that?
George My Owners Gallery Page 1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running. 1995 BMW 525I 2001 Highlander- kid mover |
Pretty easy fix ...
Step 1 - rip out stereo Step 2 - throw stereo in trash Step 3 - start up the Porsche-6 symphony while rowing thru the gears Side benefit ... the car is now lighter and therefore faster
Project935 Tube Chassis Turbo RSR/934/935 racer - SOLD in 6/'06 Gruppe B #101 What's next? |
That is true but it beats tossing it into the garbage
one of gods prototypes
he could do that but that but i would use a relay inline instead.
THEN this is the trick so he won't lose memory.......there are some small "battery backup" batteries used for security systems should the thief disconnect the battery, hook one up between the relay and the radio, memory saved. i can check monday where to get them. if you have amps you can do this by using a heavy duty cylinoid on the amp battery wire, don't need battery backup there.
Brought to you by Carl's Jr. |
35ma, or less, is what i always thought was tolerable. tell the radio guys about it. i've sent a lot of folks back to where they bought the radio items. usually they got a new unit.
And my wife was blaming me for leaving something on.
Is there a good battery disconnect that I can use for the SC? There aren't any decent radio stations in this town anyway.
Thanks, Mike When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE. 1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation) |
I use a marine battery ground clamp with a wing nut to cable disconnect.. there are switches that mount on the battery.. I just don't like the idea of another switch in a critical place.......Ron
