-   -   Need help w/ trailing arm & sway bar drop link (http://forums.pelicanparts.com/porsche-911-technical-forum/128109-need-help-w-trailing-arm-sway-bar-drop-link.html)
KFC911 09-19-2003 07:47 AM
Oops, lets try this again...
KFC911 09-19-2003 07:53 AM
I was re-indexing my rear torsion bars last night, and noticed that (what appears to be) one of the drop link 'sleeves' has seemingly pulled out a bit from the aluminum trailing arm. Here's a picture depicting what I'm talking about:
http://forums.pelicanparts.com/uploa...1063983181.jpg
Have I done any 'real' damage here, and would it be OK to (with a C-clamp) simply press it back into the trailing arm? I apologize for the fuzziness of the attached picture (...at least I hope it's here), and am looking for the best way to deal with this. Thanks![
rob justice 09-19-2003 08:23 AM
They are ment to be like that - I will post photo later but it looks ok
KFC911 09-19-2003 09:21 AM
Thanks Rob, You've made my day a lot better! I noticed this late last night, and thought for sure that I'd screwed something up...
911pcars 09-19-2003 12:17 PM
I've never seen the drop link threaded insert pull out of a control arm before, but that doesn't mean it hasn't happened. I don't think "They are ment to be like that'.
Once you press the insert back in, I would center punch the area around the insert to keep it in place. If it comes out far enough, when cornering, the suspension will put a load on it and possibly distort the boss.
MHO,
Sherwood Lee
http://members.rennlist.org/911pcars
KFC911 09-19-2003 12:25 PM
Thanks Sherwood! I spotted this late last night (and I had the car jacked up on one side only), so I did not compare it with the other side. That's the first thing I'm going to do when I get home, but I sure don't remember it looking like that before. I'll repost when I get more info, but thanks again for you suggestion!
Have a great weekend everyone!!!
rob justice 09-19-2003 01:59 PM
here's the photo
http://forums.pelicanparts.com/uploa...1064005125.jpg
