Send a message via Yahoo to tmctguer
garage queen with intermittent starting problem
I KNOW, I KNOW............you're supposed to DRIVE your cars !!!! (flame me later)
here is one for the electrical savvy folks:
i have a garage queen ('89 speedster) that i drive VERY infrequently. i have a 2 year old battery in it that i have charged approx. every 4 months due to it draining in between times i drive the vehicle.
in the past, i have been able to put the battery on a charger, and the car will start right up. however this time, the car exhibited unique behavior when i tried to start it.
when the key was turned, i could hear the starter attempting to turn. but it would not turn. i tried it several times with the same result. i assumed the battery had lost its charge and went to start my other P-car. thinking i would give it one more try, i turned the key again, and this time the starter worked as normal and the car started right up. there was no sign of a weak battery-driven starter.
i drove it for about 30 minutes, and when i attempted to re-start the car after sitting for about 15 minutes, it exhibited the same behavior -- turn the key a few times with nothing but a click. after a few more tries, the car starts right up.
when i stopped driving the car for the morning, i tried to immediately start the car after turning it off. it fired right up. however, 8 hours later i tried to start it and the symptoms started again (several key turns before the starter works and the car starts). ditto for the next day when it sat overnight.
the car has very low miles on it, and is not driven often. i'm looking for ideas:
1). could the starter be freezing up due to lack of use?
2). could the connections to the solenoid be corroded?
3). could the soleniod be freezing up due to lack of use?
4). could my battery be dying from being drained/charged over a 2 year period?
any ideas would be appreciated.
Old 09-20-2003, 05:52 PM
GB83SC's Avatar
Sounds like a solenoid issue. Make sure the starter contacts are clean.
And you know drive the car please!
George
My Owners Gallery Page
1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running.
1995 BMW 525I
2001 Highlander- kid mover
Old 09-20-2003, 06:43 PM
I would check the battery first. Did it take a full charge?
Old 09-20-2003, 07:11 PM
Sounds like battery. Disconnect if you are letting it sit for a while. There is always something causing a draw(even a wiring fault).
Old 09-20-2003, 08:10 PM
i was leaning against the battery being the problem since it eventually starts right up with the starter turning very strong.
Old 09-21-2003, 12:00 PM
Timing?
Old 09-21-2003, 01:03 PM
GB83SC's Avatar
If you are leaning towards the battery, drive the car to any auto parts they can test it for free right in the parking lot.
George
1995 BMW 525I
Old 09-21-2003, 01:14 PM
Sports Purpose 911 Driver
mjshira's Avatar
solenoid.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 09-21-2003, 03:37 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
Solenoid going out, or connector corroded.
My $0.02 - I'd try to find out whats causing the drain. I've let my '85 ( and other sleds) go for longer than that without a charge and never had a problem starting them up.
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 09-21-2003, 04:23 PM
i am with Icemaster. i'm going to try to check out the soleniod. i've looked at the Bentley manual and it looksl like a real pain in the *ss to get to! in order to change the starter, it recommends that the tranny be dropped 6 inches.
anyone with experience with a starter and/or solenoid change on an '89 911? can you do with it without lowering the engine?
Rick G.
1973 911E (sold)
1989 911 Speedster (sold)
1993 Beck Spyder
2006 Ford GT (why I sold my Porsches)
Old 09-21-2003, 07:26 PM
