Nothing like a 911
FrankieG's Avatar
Targa Weatherstripping Replacement
I need to replace the weatherstripping around my Targa bar. I bought a nice clean almost new replacement from a guy on Ebay. Any tips or anything I should know before doing it? Is the best adhesive 3M? How do I clean the area after I tear out the old rubber? Any particular tool best for this? Thanks!
1982 911SC Targa
2009 Cayenne
If it doesn't kill you...it makes you stronger
Old 09-21-2003, 07:09 PM
be careful w/this. i had a problem b/c the extra thickness of the new weatherstripping raised the targa top slightly. this gapped the window slightly leaving more space. however, this will not likely be your problem b/c i replaced the front weather stripping also.
isaac
76 911 targa-project
91 ferrari 348-sold, broke my heart
73 vette convert-gone
Old 09-21-2003, 07:44 PM
greglepore's Avatar
The front weatherstriping has a known issue with thickness for cars (89 and pre, I believe?). The rear seal should be fine. 3m weatherstriping adhesive is fine for this. Just be neat, it can be stringy/messy.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 09-22-2003, 07:50 AM
Senior Member
Jdub's Avatar
Do not attempt to drop that front weatherstripping into the channel. You MUST trim it as per instructions you can gather from Dan at CarsInc. If you don't trim the extra (provided for the later Targas that were redesigned) you risk breaking the latches when you try to snug it all down.
Do a Search on CarsInc here and gather the information you will need.
John
'78 Targa in Minerva Blue
Old 09-22-2003, 09:18 AM
