-   -   Part Number And Wholesale Source for Seiko-Seiki (http://forums.pelicanparts.com/porsche-911-technical-forum/128586-part-number-wholesale-source-seiko-seiki.html)
RandalJ 09-22-2003 05:07 PM
I have a shop replacing the stock Denso compressor on my 86 Carrera, and I'd like to try the Seiko-Seiki rotary. Does anyone have the Seiko compressor part number and a wholesaler name, preferrably in the Phoenix area?
I've done quite a few searches, but have only found Scottsind.com retail so far.
Pelican A/C section appears to be not open for business yet.
RandalJ 09-22-2003 05:22 PM
Forgot to ask, is a special mounting bracket required? Or does that come with the compressor?
jdowty3 09-23-2003 03:58 AM
I don't know the correct model but here is a couple online sources. I think an adapter plate is required. Hopefully someone with a Seiko will post more specific info.
http://www.autoaircompressors.com/seikoseikicomp.htm
https://a-aironline.com/default.asp?CatID=17
RandalJ 09-23-2003 01:55 PM
Thanks, Jim.
Adman 09-23-2003 04:19 PM
I got mine from Performance Aire. I recall it costing $550.00
I checked and there are no part numbers on the compressor. It appears that Performance removes them and replaces with their own sticker. The adapter plate is a Performance Aire casting that comes with the compressor.
