jk911's Avatar
Question Engine number
Can anyone tell me what car this engine is from
engine number 6303506
Old 09-22-2003, 07:18 PM
ttweed's Avatar
That number doesn't show up in the charts I have. What is the Type #?
630 0001 thru 630 2480 shows as a 1970 911S, Type 911/02, mechanically fuel-injected 2.2 liter motor, but that's as close as I can find.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 09-22-2003, 07:47 PM
jk911's Avatar
Its a 78sc which is for sale with a 3.2 L engine in it !
Im trying to work out what car the engine came from !
Old 09-22-2003, 08:37 PM
Tinton's Avatar
63Dxxxx would be an 83 Euro(rest of world) engine.
Porsche 993 & Honda CBR250RR
Old 09-23-2003, 12:40 AM
6303506 looks like a euro '80 3.0L to me. My euro '80 is 6301010.
Get the engine type number. 930/09 or 930/20, etc.
Rob
1980sc
Old 09-23-2003, 07:40 AM
jk911's Avatar
is it possible to replace the 3.0 cis with a 3.2 DME ?
heres a pic !
Is there any chance this could still be a 3.0 L converted
Old 09-23-2003, 03:49 PM
Hilbilly Deluxe
emcon5's Avatar
Interesting. Looks like a 3.0 distributor with MSD ignition. I don't think 3.2 distributors had vac advance units, or were adjustable for timing (the slot on the mounting stud).
It may be possible to use the DME from the 3.2 with a old style distributor and just ignore the ignition signal, but I haven't heard of anyone doing it. It is also a step backwards from the DME controled timing curve of the 3.2. You would have to change the drive gear on the crank because a 911 SC 3.0 distributor turns the opposite direction of every other 911 engine.
It could also be an aftermarket EFI setup using the 3.2 manafold. I think Clewett does this, but their systems also have crank-fired ignitions with coil packs (at least when I looked into it).
Curious.
Tom
Edit: Spellin'
82 911SC Coupe
GTI Cup #43
Old 09-23-2003, 04:11 PM
901/05's Avatar
mystery engine...
the 911 redbook pg. 71 indicates that it could be from a 911SC Aug 79 through July 80 #6300001-on (930/09) 4,831 produced.
Shawn.
'99 M96 2.5 Liter
Old 09-23-2003, 04:19 PM
jk911's Avatar
oohh ..
This is getting more interseting. This is quite a wierd engine !
Clearly this is not a genuine 3.2 carrera engine is it ?
Old 09-23-2003, 05:08 PM
jk911's Avatar
bump
Old 09-24-2003, 03:42 AM
Did you find the engine type number? That is the best way to narrow down what you have.
Brian
'73 Carrera RS
'71 911S coupe 'Patrick'
'16 Cayman GT4
'91 C4 coupe
Old 09-24-2003, 04:31 AM
