windshield rubber
I need to replace the windshield and rear window rubbers Are the ones avable from our host "Factory " a few shops around town will not touch the job unless the rubbers are from Porsche This seems to be what they will only use. because of fitment problems with aftermarket stuff.
Old 09-23-2003, 09:56 PM
koollay's Avatar
Send a message via AIM to koollay
The key is the molding.....if it is bent then it can be a long day! The back gasket you will still have to drill or route holes in the gasket for your rear defrost and then stuff them in the new rubber.
Old 09-23-2003, 10:35 PM
walt's Avatar
I've had the aftermarket and OEM in my hands. Couldn't tell much difference between them. Wound up using the aftermarket at about 1/3 the cost.
Walt
82SC 3.0
81SC 3.6
Old 09-24-2003, 02:53 AM
gregk1's Avatar
I also have aftermarket seals with no problems. I have a glass buddy that gets me a windsheld and seal for about $108, So when I take one out I allways put New glass and all back in, And as koollay says the molding can be a real pain if it's messed up
65 911/ 301274 sold
66 911 /303509 sold
67 911/ 355032
68 911 softie sold
70 T with s trim
Old 09-24-2003, 06:21 AM
Very important to get the wide flange windsheild gasket. My car is at the paint shop bein assembled. Just bought all the gaskets myself. I would not use cheap gaskets for the front and rear window. They will not fit well and you will end up with wind noise in the front.
1975 911 Carrera BLK/BLK
Old 09-24-2003, 06:55 AM
Old 09-24-2003, 07:00 AM
