collier's Avatar
NE reference on how to wire my 911 as a track car?
I know that this might at first sound odd, but I am wanting to wire my car for track use, not for daily driving....so I am looking for a wiring schematic, or reference for doing this...
Does anyone have experience, or drawings for this?
I was thinking of just buying a "wiring" kit from Summit, and using it to wire the 911?? Any thoughts on this?
I want to still have turn signals, and most importantly, brake lights
But all the other "add-on" stuff is not necessary......
Will this affect the starting/running of the car?
Will this affect the tach or speedo?
Will this affect any supplementary gauges that I add?
Would I be better off just modifying my stock 911 harness.
thanks,
chris
C2Motorsports Inc. 502.895.3660 | Engineering | Fabrication | Manufacturing High Performance Automotive Hardware and Software
70 911E*71 911T*72 911T*73 911*76 911 SC- Euro
Old 09-23-2003, 12:37 PM
What specifically are you wanting to change?
1968 911L
2004 Dodge Dakota SLT Plus
Old 09-23-2003, 12:38 PM
Super Moderator
cstreit's Avatar
CHris... Try posting on the racing board as well, I know a number of guys that have probably done this go there....
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 09-23-2003, 12:39 PM
Chris,
The easiest, cheapest and most didactic way to do that is to remove the non necessary wiring yourself. That way there is no guessing how to re-wire the essentials, you can check the condition of the remaining wires, and you'll know your car's electrics like no one.
I have done this, and it was huge fun and big teaching course.
GeorgeK
Old 09-23-2003, 12:56 PM
collier's Avatar
Wiring the car just for the basics
Well, I open the hood, well trunk of my car, and it looks like a bowl of spaghetti.....blah ! ! ! ! Much less that fact that the fuse panels are in terrible shape....
I like order
I started getting rid of things that I didn't need:
-door light pins
-glove box light
-cig lighter
-fog lights
-OEM Porsche clock
-rear defrost
-radio
-etc.
I would like to have it so I can get into the car, turn the key, start the motor, and go.
I would like to retain brake lights, turn signals, instrument lights, and that is it !
I also hope that this allows me to clean up the trunk area.
The weird thing is, I started deleting stuff I didn't need, and then the right side, rear parking light came on
Old 09-23-2003, 01:04 PM
I would rather be driving
jpnovak's Avatar
I asked some questions about the engine wiring harness. I did not get much response. Just find the circuits you don't need, find the wires and remove. Its
71/3.0 swap - engine wire harnes ???'s
Just find the circuits you don't need, find the wires and remove. Its pretty simple, although removing the harness, untaping, and tracing is the hard, time consuming part.
Old 09-23-2003, 01:18 PM
