kumma's Avatar
H4 bulb terminal sockets or connectors
i need flag or straight connectors to hook up my H4 bulbs. or even a heavy duty socket. my old wiring was corroded so badley it fell apart. i rewired the headlights with relays and thicker wiring. the only import store in metro detroit had a cheap connector with thin wiring.
any body have a source for these. anywhere.
i found these in england but its a tad far for me to go.
http://www.autoeurope.co.uk/productinfo.asp?productID=580
craig
Old 10-04-2003, 03:03 PM
Early_S_Man's Avatar
Porsche Crest
Craig,
Non-insulated Faston connectors can be used on the H4 bulbs directly ... no plastic or ceramic 'nest' connector is needed. I recommed soldering the Faston connector after crimping for a reliable long-term connection!
Just put the wires on one at a time ... and don't mix up the locations! Draw a diasgram, laminate it, and store it in the glove compartment for future reference!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-04-2003, 03:51 PM
