-   -   Brake fluid refresh? OT (http://forums.pelicanparts.com/porsche-911-technical-forum/128825-brake-fluid-refresh-ot.html)
dotorg 09-25-2003 10:48 AM
I've used a pressure bleeder a good number of times, and there are ways you can use it to minimize that risk (ie, for example, don't put fluid in the bleeder... just use it for air pressure.) You have to have someone watching carefully to endure the resevoir doesn't run dry, but that works fine.
