Weight Loss in the Rear
In the '84 Carrera, we are thinking of going w/ SSI's and a Monty Dual Out Exhaust. What weight loss range should be expected with these mods? Anyone have experience about how the weight loss feels? Also, what does the spare tire weigh?
anyone?
I have no idea how much weight you will lose - I would guess maybe 10 -15 pounds. From my experience with similar changes on other Porsches, you will likely not notice any difference. That does not mean it will not help - it is just very minor.
On the spare, pull it out and weigh it - maybe 15 pounds. I would leave it in place as it is part of the cars crumple zone and helps to even out the front / rear weight balance.
Bill |
I don't think you'll lose much weight in the rear, but you'll lose some. It kinda depends on how much the Monty weighs. The stock muffler on an '88 weighs about 30-35lbs, and the SSI's will probably weigh about the same as the stock heat exchangers and maybe the crossover pipe. I can't imagine that the cat weighs too much. I would think total loss would be 10-15 lbs, and when you consider the back of the car probably weighs about 1600 lbs give or take, even at 20 lbs you are only talking about 1.2% of the weight of just the back.
Your best bet for weight loss will be to do lots of little stuff over time that 5-15 lbs here and there adds up. If you want big savings you'll likely have to go with replacing major body panels (bumpers, hoods, fenders), wholesale removal of large systems (A/C), or replacing items with much much lighter items (seats, windows)
PRO Motorsports
About 11 pounds if I remember correctly. 65 for your stock exhaust, and 15 for each SSI, and 24 for the stock muffler for a total of 54#. If your Monty weighs more than 24, then savings will be less.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
