AirCooledExcellence's Avatar
Thinking of buying this - Am I MAD??
Hi Guys,
This 1969 911E is on eBay at the moment £2000 at the mo:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=2433125948&category=29758
It's got a broken engine, but body work is fine (apparently!)
I'm going to see her on Saturday (any tips on what I should look for?) and as long as the body checks out OK the plan will be to sell my SC and use the funds to restore this one.
I'd probably put a recon engine in it, I've tracked down a rebuilt 2.0S engine (would the old one be worth anything?) and should still have money left for a decent paint job.
So guys, am I completely mad??
Cheers,
Tim.
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 09-18-2003, 11:19 PM
Roy M's Avatar
Not mad but you'll ned some time! Personally I'd go for an RS replica with a 3.2 engine (it's never going to be original is it!) If you're prepared to sink another 10K into it you'll have a fantastic car as long as the rust isn't terminal.
What to look for? - RUST - everything else is easily sorted!
Good Luck
Roy
Old 09-18-2003, 11:47 PM
layzee's Avatar
That thing just HAS to be rusty! Guy obviously knows nothing about the car 'rare G50 gearbox' - in 1969?
Depending on how much it goes for, it might be a good buy, but I don't think it will stay that low.
I agree with Roy though, if you are going to do an engine swap, you might as well go for a later one, 3.0 or 3.2 then you can have a real hot rod.
Phil Garner
'72 911E Sporto
Sportomatic.org
Old 09-19-2003, 01:07 AM
looks like it could be a nice parts car, if nothing else -- let us know what you think after you've seen her. I might be interested, but i wouldn't bid against you, of course.
Old 09-19-2003, 01:54 AM
Siena911's Avatar
Tim,
Not mad but it is a long haul,
How much working space have you got to tinker in?
I vaguely remember seeing either a clip or photo of your garage and there was not that much room? Could be mistaken though.
Yep rust is going to be your biggest problem.
B posts
Lower sills especially where the b posts join them
check area above rear tail lights
around headlights
check the inner wings, from underneath and inside (boot) lift the carpet.
check the lower front chassis pan, where the a-arms bolt onto.
around the windscreen, try and lift the rubber in the lower corners to get a good peek
Then lift the carpets and look at the floor all over
check under the battery etc.
Rear window area
And Im not sure where the oil tank sits on that one, but on mine I had 2 inches of dirt, grit, salt on top of the oil tank inside the rear fender and this eventually rusted a small hole through the inner rear.
Go with caution and do the deal with your head and not the heart (ask me how I know )
Take a magnet with you to "feel over" the body work, the attraction should be the same over the whole body and if an area does not feel as if it attracts strongly, that could indicate some filler of sorts
Good luck mate and keep us informed
Cheers Jakes
p.s. as for the motor, Go big and bad!!!!
If you want to run with the big dogs, you can't pee like a puppy!!!
92 Rover Metro 1.1 (54 manly horsepower) - Dont knock it it does 60 mpg!!!
81sc / 3.2 litre transplant (Broken BIG Time )
SCWDP deserter - HP junkie wannabe
Tim, I posted comments about this car over on the PCGB forum but in terms of the engine you might get a pleasant surprise - I would be very surprised if a camshaft is actually broken - the rockers are designed to be the weakest link & they will shear first before any damage is caused to the cams.
Andy
'69 911E-------->R
Andy
M&W 904 ... now gone
GT-style 356C ... also gone
Old 09-19-2003, 02:44 AM
pwd72s's Avatar
I'm with Evren on this one. Judging by the pics, I'm thinking it would take a LOT of money to put this car back into driving trim. More than it would cost to buy a nice car in the first place.
Old 09-19-2003, 09:55 AM
nigel911's Avatar
Someone's got to buy it otherwise we will have lost another early year 911...
As an aside, I would have thought it might be worth that in parts?
Old 09-19-2003, 12:31 PM
911 user
Milu's Avatar
Yes you are mad. You are condemning yourself to a Porscheless driving period for a while, setting yourself up for a lot of hard and frustrating work, endless scrapes, scratches and booboos, nightmares of little niggles and snags to sort and a bottomless moneypit for your sparecash and you are trading a good car to do it.
Go for it in the full realisation that you are just as crazy as the rest of us!
Where once the giants walked now Mickey Mouse is king.
My other car is also a Porsche.
Old 09-19-2003, 10:57 PM
Thanks for the encouragement guys. I'm off to see it in a couple of hours, I'll report back later!
Cheers,
Tim.
1987 930 - SOLD
Old 09-19-2003, 11:08 PM
Senior Member
Doug Zielke's Avatar
Re: Thinking of buying this - Am I MAD??
Originally posted by AirCooledExcellence
the plan will be to sell my SC and use the funds to restore this one......
Certifiably so!
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 09-20-2003, 06:30 AM
Non Compos Mentis
You may be mad.
I drug a '73 home on a trailer from an insurance auction.
Sat on jackstands in the garage for over a year before it was able to move again under it's own (transplanted 3.2) power.
Was it worth it? You bet. Makes every other car I've owned feel like a turd.
Old 09-20-2003, 06:44 AM
nigel911's Avatar
Love it! Sums it up rather nicely.
Old 09-20-2003, 07:09 AM
But, it's a good mad!
Scott
Old 09-20-2003, 07:11 AM
Glasgow 911SC's Avatar
Update Tim?
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 09-20-2003, 10:06 AM
I'm afraid of what you'll find under the floor mats. If you have a rotissorie, the restoration job will be a little easier.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 09-20-2003, 10:23 AM
Kantry Member
oldE's Avatar
Barking! On one hand you've got a (nearly) clean slate on which to illustrate your personal vision of 911 perfection. On the other hand, have a look at the nearby thread detailing the cost of just that to another 912 body. Oh heck. Buy it and do it! (But buy it cheap!)
Les
Best
Les
Old 09-20-2003, 11:26 AM
Binge User
Schrup's Avatar
Tim.
My God, you've gone stark raving mad!!! See what happens if you don't take your medication as prescribed. Trading your fine SC steed for a longnosed bastard. It's the work of the Devil I tell you. You will be damned to the internal perils of Gruppe B. Repent while there's time, all can be forgiven.
Paul
Old 09-20-2003, 12:42 PM
Zeke's Avatar
What is 2000 lbs. (sorry, I don't have symbol) in USD? I thought that would be close to $4000. That's a lot of money for anything too rusty. I have a rust bucket and I can see the 100's of hours for rust repair and eradication. BTDT on the 914.
Old 09-20-2003, 02:05 PM
layzee's Avatar
About $1.65/£1 at the moment. $3300ish
Phil Garner
'72 911E Sporto
Sportomatic.org
Old 09-20-2003, 03:07 PM
