Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Just swapped alternators...now car won't fire.
Hi,
I have a 3 liter motor in my 72T. The alternator went bad, so I got a whole new fan/alternator combo. I marked the wires and took pics, and hooked everything back up to the right spots. Now the car turns over, but won't fire. Any thoughts?
Thanksm
mto
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 09-24-2003, 04:11 PM
Check for loose/disconnected wires (including wire from the coil to the center post of the distributor cap) at the coil and distributor. Jim
Old 09-24-2003, 04:53 PM
Rennch on YouTube
rennch's Avatar
I looked...nothing apparent, but still checking.
Michael O'Neal -
Old 09-24-2003, 06:18 PM
72 four door's Avatar
Did you hook up the ground inside the alternator to fan?
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 09-24-2003, 07:42 PM
Rennch on YouTube
rennch's Avatar
yep...all the wires are hooked up. I hate the feeling that I missed one, but I'm pretty positive that I hooked 'em all up.
Michael O'Neal -
Old 09-24-2003, 11:39 PM
jabb's Avatar
Are you getting Spark to the plugs ??
Fuel pump on ?
Did you disconnect the battery when replacing the Alternator ?
Did you ground or short anything while replacing the Alternator you could have blown a fuse or a relay ?
Just some things to check
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 09-25-2003, 05:43 AM
304065's Avatar
The car will run with the alternator disconnected. The problem must lie somewhere else.
Did you crack the coil re-attaching it?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-25-2003, 06:00 AM
l8tapex's Avatar
How about the fuel pump relay. Just a thought.
92 C2 Turbo Coupe, Gran Prix White
Tial 46mm .5bar, k27 7200 11/11 LF
Welded in Roll Bar, Sparco Pro2000 seats, RS Carpet Set
Old 09-25-2003, 08:03 AM
TerryBPP's Avatar
Sorry to hijack your thread, but where does the ground hook up to the alternator? I pulled mine off without checking.
Old 09-25-2003, 08:29 AM
Somewhere in the Midwest
MotoSook's Avatar
terry..large brown wire that's attached to your case..connects to your alt, on a stud of the alt housing.
Old 09-25-2003, 08:58 AM
TerryBPP's Avatar
I meant, which bolt do I use on the alternator? I know where all the others connect I just missed this one.
BTW: You encouraged me to get my fan and shroud powder coated. Looks great. I post some pics later.
Old 09-25-2003, 09:43 AM
Rennch on YouTube
rennch's Avatar
Here's a question for you guys: I painted and clearcoated my fan and housing. Could it be that the coil isn't getting properly grounded, so it's not working? Because it's sitting on paint, instead of metal?
Michael O'Neal -
Old 09-26-2003, 09:50 AM
Id say its a good bet behind the plate i would scuff up the area where you ground those wires .
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 09-26-2003, 10:07 AM
Early_S_Man's Avatar
Porsche Crest
The coil doesn't depend on the fan housing for ground ... there is a braided ground strap tying the coil, distributor, and CDI-unit together in the engine wiring harness.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-26-2003, 10:10 AM
Rennch on YouTube
rennch's Avatar
Hey fellahs...I got it! As it turns out, it was the battery all along. I bought an Odyssey 925, relocated it to the passenger side, rewired everything, and she fired right up after coughing for a bit! I guess it was just sitting too long. Sorry to waste the bandwidth, and your time.
Thanks to everyone.
Michael O'Neal -
Old 09-26-2003, 05:36 PM
