if there was a boken belt you would feel it no matter which way the tire was turning, what exactly did you do .. dismount the tire and reverse it?
i have never seen i broken belt from the mounting dismounting prosses but i guess its possible. also please take no offence to this as it has happened before are the lugnuts torqued correctly? Kyle |
No shimmy when I picked up the car. I drove the car for a couple of days before I noticed that the rotation arrow on the front tires were pointing the wrong direction.
I removed them myself and switched sides they were mounted to. This is when the shimmy started. I then had the wheels/tires balanced and the shimmy remains. James |
Oh and this whole thing is about to be moot. These are 15 inch cookie cutters and I'm moving to 16 inch fuchs.
James |
OK,
So I cant let this thing go cause it's gnawing at me and I'm thinking that I might have wasted a whole lot of money and took some bad advice on my last car. Try and try and try to find proof of what I was told earlier about tires, and end up proving myself wrong. At least the next owner had a cherrey suspension. Learning experience. My deepest and humblest apologies to all, I was wrong. |
I'll let you know tomorrow morning if the car shimmies with the new wheels and tires. I won't let myself drive the car with the present "2 spoke" steering wheel.
New arrived today. I'll try to install tomorrow morning. James |
I've been running one (front) Bridestone in the wrong direction for a couple of months now. Noticed it too late, just left it like that. My little experiment. I run the car fast on rough roads, frequently. Even particiated in a time trial. No problems. In fact, if I brake hard (on a dry road), it seems to hold on a moment longer han the "correct" tyre. It doesn't seem to wear any faster or slower that the left tyre. Won't run it in the wet, though. As far as I know, the only problem lies with water dispersement and aquaplaning.
By the time our wet season starts, I'll need new tyres anyhow. |
did anyone see see the article in grassroot`s motorsports a few months ago they ran the tires the wrong way on a dry tack and again on a wet track.
it was interesting they actually performed better running backwards on a wet track. it was a good article late K |
Update:
The wheels installed on the car were H offset not J. I was getting a rub on some turns, not sure if this had any effect on the situation. With the 16 in Fuchs (J Offset) installed with 205 55 16's (Perelli P6000 Z Rated), it runs and tracks wonderfully, and no shimmy. See new thread on the steering wheel update.... James |
| All times are GMT -8. The time now is 04:20 AM. |
