Wildman Emeritus
Sunroof ??
I'm in the process of replacing cables, guides, seals, et'c. & have it all back together. Have reviewed the tech data from PP.
However, I can't see to get the rear height adjusted properly so that I can reattach the trans & finish. I can get it to the proper height using the adjusters but when I release it , it drops slightly. If I connect the trans will the pressure on the cable keep it at height or am I missing something in the tech data. 101 Projects & Bently.
Any suggestions are more than welcome. I want to be back on the road.
Old 09-26-2003, 07:43 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
The roof panel relies on the cables to hold it up when closed. Sounds to me like you've done everyhing correctly.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 09-26-2003, 08:49 AM
Wildman Emeritus
Thanks, Kevin. I guess I was on the right track.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 09-26-2003, 08:53 AM
makaio's Avatar
Ditto to what Kevin said.
Old 09-26-2003, 01:07 PM
