Fidalgo911S's Avatar
901 transmission question
My 901 5-speed works really well except for when it's in 5th gear. At mid-range and lower rpm's, it'll pop out of gear when I go uphill and put a load on it. I'm not sure what the miles are as I bought it used to replace the previous 901 tranny that gave up the ghost.
I changed all the shifter bushings the other day (huge improvement in the feel , by the way) but it still popped out of gear. Any ideas what it could be?
Nate
Old 09-29-2003, 08:42 PM
SteveF_911's Avatar
Could be worn dog teeth.
66 911 with S engine
2008 Westfield XTR2
Old 09-29-2003, 09:14 PM
pjv911's Avatar
Send a message via AIM to pjv911
Check the coupler adjustment . Its in front of the rear seats under the metal grill . I think you should have no trouble finding the correct adjustment procedure if you search this site.
BTW how is 3rd gear ? That too could be affected(as far as the ajustment theory goes) if 5th is giving trouble.
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 09-29-2003, 10:47 PM
First and third gear are great; no problems. I couldn't find a coupler adjusment for the 901 on this site. There's one for the 915 in the tech articles, but that's a horse of a different color....
Nate
Old 09-30-2003, 08:26 AM
