-   -   Woo-Hoo Removed A/C ! (http://forums.pelicanparts.com/porsche-911-technical-forum/129389-woo-hoo-removed-c.html)
Type911 09-28-2003 02:26 PM
I have been thinking about removing my a/c system on my
82 911 for months now. Its a Targa, so I really dont need a/c, plus its an inefficient system & makes my car run hotter when on.
Had the sys. evacuated, removed old York compressor & condenser, cut a/c lines...took about an hour.
Nice to have an engine compartment that looks cleaner & is easy to work with...plus the car runs about 10-15 deg. cooler now
with better airflow thru the decklid vents !
Any idea what I should do with the old parts?
I cant see keeping them, probably throw em away, and just keep the compressor
bracket. SmileWavy
-Chris
RoninLB 09-28-2003 02:32 PM
I gave all the AC stuff away to a guy who wanted AC in his old 911.. the condensor and evaporator may be worth some bucks
larry47us 09-28-2003 02:51 PM
Chris:
Check for a PM.
larry
CarreraS2 09-28-2003 03:00 PM
What lines did you cut?
Wouldn't it have been cleaner/easier (well, at least cleaner) to simply disconnect all the lines at their termination points?
Type911 09-28-2003 03:56 PM
Well, I was doing this quick & easy, so I just cut the lines going to the evap. within the engine compartment. No fuiss & you cannot even see whats left of them
I considered pulling all the a/c hoses that run under the left/right
side of the car, but its Sunday & I wanted the quick & easy way out so I could enjoy the rest of my day :cool:
If I ever add a/c back into the car I will update the hoses.
RoninLB 09-28-2003 04:07 PM
yep.. I believe stock is obsolete........Ron
stealthn 09-28-2003 07:59 PM
I want to do the same, but remove the whole system. My issue is when I tried to get it evacuated the mechanic couldn't get the valve covers off; they were seized.
What do I do now, I think there is still some freon in the system.
GSpreeman 09-28-2003 10:15 PM
Is anybody throwing away a A/C blower motor? (Or whatever is in the smuggler's box?)
jazzbass 09-28-2003 10:38 PM
I stuck mine is a big storage container in the basement. I keep toying with the idea of selling the condensors and fans on eBay, but never get around to it. Start the bidding at $1 with no reserve. Sold the blower motor to a local board member. I'd keep the main parts - you never know when you can use them for trade fodder.
