No Brakes !
I went for a drive in the mountains this morning. Coming down the hills, I noticed some brake fading on my 83 911 SC. After I got to the bottom, I noticed pulling to the right, as if the front right brake caliper was binding, and detected a brake odor. A block away from my house brakes failed completely; pedal went to the floor. Luckily, I was going slow enough to use the hand brake. After getting home I inspected for leaks. None could be found. Did my master cylinder give up the ghost or what?
Old 09-28-2003, 12:47 PM
GB83SC's Avatar
Wait for cool down. If fluid is full then press brake, if it goes to the floor with no brake activity then the master cylinder is gone. At this point I would remove all wheels and check pads.
Glad you made it home safely. (someone was watching out for you)!
George
My Owners Gallery Page
1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running.
1995 BMW 525I
2001 Highlander- kid mover
Old 09-28-2003, 01:18 PM
Thanks, someone was watching over me. i came down that hill pretty hard,its a 7500 foot decent to the desert floor in Palm Desert,CA. if i had lost them on the way down i might not be posting this right now.
I will let it cool down and do what you said, the fluid level is up,I have noticed a slight pull to the right from time to time and lately the brakes just havent felt as possitive as in the past.
Old 09-28-2003, 01:33 PM
Early_S_Man's Avatar
Porsche Crest
The 'pulling to the right' and the scent from the overheated pads tells me that you don't have a master cylinder problem ... at least it didn't cause the failure you describe! It could be a blown caliper-to-piston seal, or even a blown rubber flex hose ... but, I think putting the front up on jack stands and inspecting your calipers with the wheels off is definitely called for!!!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-28-2003, 02:00 PM
I let the car coll down for a few hours and the pedal is back,a friend of mine says that the fluid may be so old [it is at least 6 years/10,000 miles
old] that it failed in some way, i do think that the front right caliper has a problem. the pedal went to the floor,yet theres no leaks of any kind.
Old 09-28-2003, 04:47 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
You may have "boiled" the brake fluid.
Old fluid absorbs water...making it boil at a lower temperature.
Try changing the fluid for a start....trhen test again...but not on that hill!
Bob
Bob Hutson
Old 09-28-2003, 04:56 PM
Im pulling out the power bleeder i bought 2 years ago and flushing the system out. I hope that cures it.
Old 09-28-2003, 05:02 PM
