I be learnin
1st valve adjust and oil change done and what I found out.
1. Don't drain the oil tank into a 2 gallon bucket it is messy. 2. Make sure the screws on the .004 feeler guage are tight. Don't ask me how I know that but I wasted an hour looking for the parts. 3. I took the feeler guage sold by Pelican and bent it by the screws from app. 30 degrees to 90 degrees and it slid in much better. 4. Next time I will put the sparkplugs back before I install the valve covers. 5. Found out I am back in the 60's with LSD :D Next project is Front brakes, Wheel bearings, Caliper rebuild, and New rotors. Staring Monday The good times keep on Rollin!!! Peter |
Congrats! BTW, I did the same thing with my Pelican Parts feeler gauge and it also worked better for me too.
P.S - Share the LSD :-) |
Congratulations. I completed my first valve adjust a few weeks ago. It's a bit messy, but no problem...just have to follow the book. I decided about a year ago that half the fun of owning a well-used 911 is keeping it in top shape. I'm sure you've figured out that this board is an incredible source of knowledge and expertise. Good luck with your other projects!
| All times are GMT -8. The time now is 03:08 AM. |
