Kolibri
blackbird225's Avatar
Spring clips mystery
I have searched the posts and I did run across a few posts on this, however, I am still a little nervous.
I also have 101 projects, etc.
I have purchased new stainless lines, and I need to remove the flexible lines from the calipers, of course. When I look at this clip, there is a 17MM hex on the caliper end and the steel line connects to the other. The clip looks like its a 2 ply unit welded to the wheel well. There is a very straight 90 degree ply and a ply with a slight curve at the very end.
The posts talk about taking vice grips and yanking it out.
My question is, to what am I hooking the grips to? Seems like some people are using hammers to get this clip out.
Some clarity would be greatly appreciated.
Michael
1942 VW Kübelwagen
1940 Zündapp KS 600
1941 Zündapp KS 750
1975 Volvo C303 TGBII
1967 Honda S90, 1975 CB550
Old 10-08-2003, 02:22 PM
It's a little hard to explain, but the clip is loose, not welded to anything. Fasten your vicegrips to the curved end and pull--hard. If that doesn't work, put a punch or screwdriver on the other end and hammer it off. It's a kind of spring thing held in place solely by its spring pressure. Once you get one of them off, it'll all become clear, but youwant to pull the curved end or push the flat end.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 10-08-2003, 02:30 PM
Friend of Warren
Here is a diagram that explains what Steve is talking about. It is part number 6.
Kurt V
Old 10-08-2003, 02:33 PM
Kolibri
You are the man...
Thats why forums rule.
Without a computer and this forum, I would not have the guts to buy a 70 911T. I rebuilt a couple of 76 Honda cb550f motorcycles, and the first time without help from any group. But a car is so much more in so many ways...
Thanks again!
Michael
1942 VW Kübelwagen
1940 Zündapp KS 600
1941 Zündapp KS 750
Old 10-08-2003, 02:53 PM
