901 starter work in an SC?
Will a 901 style starter work okay in an SC? I know it's not as strong as the 915 starter, but anyone use one in a 915 to spin a 3.0L?
Thanks,
Rob
1980sc
Old 09-29-2003, 08:04 PM
CamB's Avatar
Yes, but it might struggle when it is hot. That happened to me (except I had a higher again compression 3.2, so it sucked even worse).
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 09-29-2003, 08:18 PM
jakermc's Avatar
Why would you want to do this? What advantage do you see in it?
1983 911 3.6L - NASA GTS-3 class
1998 Boxster - PCA SpecBoxster, NASA GTS-2
2003 996X51 - NASA GTS-4, PCA GTB
2003 996 Carrera 2 Coupe
2003 Ferrari 575M
Old 09-30-2003, 05:02 AM
Early_S_Man's Avatar
Porsche Crest
To utilize an SR-17 starter in an SC you will need to wire up a relay to be activated by the Terminal #50 signal to the solenoid, because the SC version of the SR-68 starter has an extra set of contacts for the cold-start system.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-30-2003, 05:56 AM
