RETIRED
Joe Bob's Avatar
Burn outs are fun, but break stuff....
At the autofest I had some fun doing burnouts in Frankensteen with my new 150hp Type IV motor.....found out I have an LSD in there, never thought to check that a 1965 transmission would have one.
Anywho, did some cool 60 foot burns with both tires spinning the 245s under the bolt on Frankensteen flares. After getting home I heard some clunking noises.....new trans rebuild time.....
Since I have NO idea how long it has been since anyone has been inside the box, I figure it needed it anyways. Problem is, this trans is gonna be a "little" more expensive than the 901s that I have pulled apart before.
Guess I will have to wait until the clutch is fully extnded before hammering it down.....
2012 ML350 3.0 Turbo Diesel
Old 09-17-2003, 08:10 AM
carlos's Avatar
Burnouts? :)
So, burnouts breal porsches? I have this 425 HP 930, and I've been dying to see what it will run the 1/4 mile in. My neighbors have a hot rod honda they say will eat my 930 up. I'm afraid to really just sidestep the clutch like I can in my AMX. Will I break things by dumping the clutch at 5-6000 rpm? I have 295's on the back too. I feel I have to defend Porsche against the rice down the street....
Fastlos
86 Powerhaus 930
68 AMX
97 GMC Z-71
Future FIA Champion, Mateo
86 930 Powerhaus Stage 1 W/SC Cams Billstein Sports Weltmeister Torsion Bars & Strut tower brace Kinesis 9 & 11 K-28's Lowered Balanced "Scary Fast"
87 BMW 735I "Kid & Grocery Hauler"
*68 AMX 390 Go Pack
4-Speed "Burnout King"
*82 Honda Trail 70 "Just Fun"
*Future Cart Champion Son, Mateo "Go Da Da Posha Go Trbo"
Old 09-17-2003, 09:11 AM
carlos's Avatar
BREAK, Not BREAL!! Sorry!
*68 AMX 390 Go Pack
Old 09-17-2003, 09:12 AM
"Will I break things by dumping the clutch at 5-6000 rpm?"
Yes
Warren & Ron, may you rest in Peace.
Old 09-17-2003, 09:22 AM
Binge User
Schrup's Avatar
I'm in no hurry to find out.
Paul
Old 09-17-2003, 09:24 AM
RETIRED
Joe Bob's Avatar
I only applied enough to break it loose. I did not side slip, but revved to 3500 and "popped" the clutch.....
Great launch but obviously too much for a 40 year old trans....
Old 09-17-2003, 09:28 AM
drag racing the short bus
dd74's Avatar
Wasn't "no burnouts" covered in the Porsche 101 class?
The Terror of Tiny Town
Old 09-17-2003, 09:40 AM
Unregistered
sammyg2's Avatar
Mikey, can you fit a 901 out of an early 911 in there instead of the 356 tranny? You'd loose the LSD but prolly save some $$$$.
This may be a stupid question, but it's one I've never seen before.
Old 09-17-2003, 12:05 PM
Mr9146's Avatar
I wouldn't dump the clutch at 5-6000 ... that would nuke the rear end. Instead, go for a more conservative 2500 RPM launch. With the turbo all you need to do is have it spooled when you side step ... but don't worry, you'll eat those rice burners regardless.
You might want to avoid the burnout box, however.
NOTE: I used to drag race my 914 with a 2.2S w/Webbers ... I ran a consistent 13.5 in the 1/4 with a 2200 RPM launch and shifting at 7200.
Old 09-17-2003, 12:17 PM
mannkar
I did a burnout in my 911 and stripped the slines on the axle. Water had wicked in there and rusted them. Burnouts locate weak points. They're a good thing.
Rob
Pelican Gallery Page
Old 09-17-2003, 12:44 PM
dd74's Avatar
In that case, sure, they're a good thing. But you wouldn't be saying this if in addition to finding your axles, that you busted your r/p, over-cooked a gear, or bent your axles entirely, which would not happen had you not done a burnout.
Old 09-17-2003, 12:59 PM
RETIRED
Joe Bob's Avatar
THAT involves moving the torsion bar tube and A LOT of welding......not ready to that.
Old 09-17-2003, 01:13 PM
Buy them, sell them
Adam's Avatar
I peeled out big time only once when I was angry, and spun those 205s (or at least one of them ) for about 50-60 feet. I blew my 1st gear synchro hub not long after.
I had the box totally rebuilt (at great expense) and it's fantastic. I worship my sweet-shifting 915 and know that it won't launch the way my old 928 5-speed used to...
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 09-17-2003, 03:47 PM
dd74's Avatar
And with that, as my friend Adam testifies, I rest my case...
Old 09-17-2003, 03:52 PM
Unregistered
sammyg2's Avatar
In my last Porsche I occasionally would rev it up to about 2500 and let the clutch out hard, nailing it as as soon as it engaged. This would result in two black marks for almost as long as I wanted to stay in it. Not bad for a 901, but I only did this in 2nd gear, never 1st
I'd never dream of doing that with my SC, not that it would be able to.
After all, it has two fewer cylinders.
Old 09-17-2003, 03:55 PM
Crotchety Old Bastard
RarlyL8's Avatar
I would think the 930 trans would take anything you could throw at them.
Before the swap my 3.0L would haze the 345s out back through first gear by simply letting out the clutch off idle THEN smashing the gas. Left 2 light 13" wide marks for about 20 feet. Clutch looked fine when removed during the swap.
Old 09-17-2003, 06:42 PM
Yes, the 930 transmission should be able to handle lots of stuff. I don't think you'll have a problem unless you run slicks, have a pre-existing problem, or have 650+ hp.
Old 09-29-2003, 10:56 PM
Don't forget this thread
How about some Pic's of 911's SMOKING the tires
Old 09-29-2003, 10:59 PM
adomakin's Avatar
you got to get the odd tyre smoker in there once in a blue moon.
thats one of the things that got me so into cars. there was nothing like watching the general lee cremating its tyres at every opportunity on a saturday morning!
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 09-29-2003, 11:02 PM
My first car, '65 Impala with a 4 on the floor and 4.11 gears, it would make some serious smoke. I still have a spot in my heart for the smell of roasted tire.
Old 09-29-2003, 11:05 PM
