-   -   Idea for a cup holder design (http://forums.pelicanparts.com/porsche-911-technical-forum/129547-idea-cup-holder-design.html)
Sonic dB 09-29-2003 02:11 PM
A can of soda pop fits perfectly between the seats. I actually wedge it in behind the parking brake.
A better idea would be to manifest a cup holder that "clips" onto the parking brake lever itself. It could be plastic with a metal clip that comes down onto the brake level and clips into place. This could hold a standard can or bottle of pop.
The only drawback would be that the bottle or can would have to be removed when actually pulling the parking brake up into place.
jyl 09-29-2003 03:48 PM
Kinda tough for those of us in SF where you routinely use your handbrake at intersections.
jester911 09-29-2003 03:54 PM
http://www.griotsgarage.com/search.j...=17&search.y=6
I installed this cup holder with a bracket I made and hinged it so it swings up under the glove box side of the dash. You can't even see it when it is closed up.
I will post some pics when I can get another dig camera. My cheap one went south.
vesnyder 09-29-2003 04:51 PM
Bump!
Bill Douglas 09-29-2003 04:52 PM
You know that box behind the hand brake, the big one with the knob on top that goes from 1 to 10 and defrost, and DOESN'T DO ANYTHING AT ALL. Well I was planning on removing the guts of it and putting a coke can sized hole in the top of it.
trj911 09-29-2003 05:52 PM
Oh no, another cupholder thread! (We had a long one a few months ago!)
My favorite is a new roll of duct tape on the floor.
wckrause 09-29-2003 07:05 PM
Here is my contribution to Porsche cup holder technology
http://www.pelicanparts.com/ultimate.../cupholder.jpg
SixThree150 09-29-2003 07:29 PM
Wait, why do we NEED a cup holder?
maxnine11 09-29-2003 07:45 PM
wouldn't be caught dead without my cup-holder!! (patent pending) http://forums.pelicanparts.com/uploads2/cupholder3M1064889867.jpg
max
wckrause 09-29-2003 08:50 PM
The need is well established, the question is how to best implement the solution.
The cup holder needs to be located near the gear shift so that you can quickly secure the cup when you need to shift.
Hazbeen 09-29-2003 08:53 PM
Bought the $35 cupholder from our host....you know the one that uses the cigar lighter. It works great and although I wish it cost less, the construction is top shelf and I am very happy with the purchase. It passes the "No bling rule" with flying colors.
Haz
Rob McKibbon 09-29-2003 09:46 PM
My wife says their "rice", but they clip on/off in 2 seconds flat. Good for those long hauls when you need some spirits at your fingertips.
http://forums.pelicanparts.com/uploa...1064897113.jpg
:eek: There was a long thread on this subject only about a month ago......
Dantilla 09-30-2003 03:35 AM
Uses the cigar lighter? To keep your coffee hot?
cstreit 09-30-2003 06:59 AM
Where else are you going to put your beer? :D
rcm 09-30-2003 09:27 AM
Ok, Walmart has a cupholder that is meant to mount down on a flat surface. Like I mounted one on the flat fender of my tractor.
However, I found they fit perfect in door pocket. You just shove down and wala. Holds a 16 ouncer of your favorite beverage. It will work even better when I replace with fiberglass pockets this winter. $1.59 in the automotive section. Now i have to admit this is not the perfect solution but, I found it keeps things out of the way and dry.
William Miller 09-30-2003 01:53 PM
I took a beer holder, the ones that hang on the window slot. I cut the hanger part off so all that's left is the two plastic arms that hug your beer and the flat bottom piece. I put this into the door pocket with the flat part (back) up against the post that holds the door handle. I screwed it on with a black trim screw. They come in many colors to match your interior too!
This works great with 12oz cans, long necks, Paper drink cups and a tall thin coffee cup with no handles. Careful, if you slam the door hard it will foam!
nostatic 09-30-2003 02:12 PM
I'm in the "why a cupholder?" camp. Your crotch is good for more than just pissing and moaning.
scottb 09-30-2003 04:45 PM
Keep both hands on the wheel and drive the ***** out of the car. Drink coffee later.
Ned nyna 11 09-30-2003 06:42 PM
I use the warm ball method to secure my coffee cup. A large towel on my lap protects me from overspray.
Ned Monaghan
braddb_82SC 09-30-2003 08:39 PM
I simply use the door pocket. Most cups and cans fit great in the space just in front of the door latch. After doing this for years there is no decernable damage to either the door panel or the pocket. I just need to be sure not to slam the door while the drink is in the pocket!
-Brad
