test pipes
I have 87 911(stock) and want more oomph. can anyone give me some feedback on whether or not I should install a cat bypass test pipe. emmissions not an issue in my area. Is their noticeable power improvement and/or any drawbacks?? thanks
Old 10-03-2003, 05:32 AM
I installed one several years ago for two reasons. One is its hot here in Houston and removing the cat I feel lowered the heat on that side of the engine. Two is its cheap and I was curious. I'm not sure it added anything other than a deeper exhaust tone which I like. My 1987 has a mass flow sensor so maybe the bypass helped but I couldn't tell. One draw back is Houston raised the emission test hurdle and I cannot pass it without the cat so it goes back on once a year. Previously I could pass easily without it. A testament to the efficiency of the engine especially since it has well over 130,000 miles on it.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 10-03-2003, 07:02 AM
thrown_hammer's Avatar
I have heard the premuffler adds horsepower and the bypass doesn't. I dont have any proof one way or the other. I just hollowed out the cat. It sounds better but cant feel any power increase. No emmisions worries here either.
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 10-03-2003, 07:12 AM
I have heard the premuffler adds horsepower and the bypass doesn't.... I just hollowed out the cat.
Yes, a cat bypass is reported to only change the tone of the exhaust, but add no power while a premuffler as originally fitted to the Euro cars and available from fabspeed is supposed to add power. Gutting the cat may actually reduce power, but the difference is probably pretty small.
Old 10-03-2003, 09:23 AM
I have an 82 SC. I do not know if the test pipe gave any increase in HP but it seems to have a little better throttle response. That could be in my head, but who cares. I believe. It sounds good and runs a little cooler, which is important here in South Carolina, where it gets real hot.
Old 10-03-2003, 10:54 AM
GB83SC's Avatar
Been there done that. Dont waste your money on a test pipe, it only lowers the temperature around the left valve cover.
I now have the Fabspeed pre-muffler, it gives you a lot better torque at a low RMP.
George
My Owners Gallery Page
1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running.
1995 BMW 525I
2001 Highlander- kid mover
Old 10-03-2003, 01:08 PM
