-   -   How to remove foglight switch? (http://forums.pelicanparts.com/porsche-911-technical-forum/129933-how-remove-foglight-switch.html)
cowtown 10-02-2003 11:13 AM
This is a bit embarassing to ask, but I don't want to risk breaking the thing, because I've promised it to someone.
Can you guys tell me how to remove the foglight switch on a '75? I have access to the back of the switch but can't see how it's mounted. Is it a press fit?
There is no screw under the knob and no clamping nut on the back.
Thanks,
Colin
Eric Coffey 10-02-2003 11:59 PM
I believe you need to first remove (unscrew) the knob, then unscrew the black bezel ring underneath. It should have 2 or 4 holes in it, and you will need cir-clip pliers, or a "modified" fork should work in a pinch. If it is tight, try pushing lightly on the switch from behind to relive tension. After the bezel is off, it should come right out from behind. ;)
cowtown 10-03-2003 07:09 AM
Thanks Eric! I did manage to get it out last night. I didn't see the little black nut that requires circlips on first glance.
Colin
