-   -   Cruise control not stable (smooth) (http://forums.pelicanparts.com/porsche-911-technical-forum/129955-cruise-control-not-stable-smooth.html)
steviee7 10-02-2003 02:14 PM
Anyone use their cruise control? I tried mine and noticed that is seems to vary, like if it's set for 65 it can go 60 and then up again. The throttle or engine is always going up and down. It's never right on. It's annoying to feel the car accelerate and slow down when it's set.
What can it be???
Is there a possible vacuum leak or WTF.
se:confused:
88911coupe 10-02-2003 03:10 PM
I've read this is tied a vacuum leak...try a search for cruise and vacuum. I think the problem is with the vac tube that hooks up to the unit in the engine bay.
HTH
Russ in VA 10-02-2003 04:45 PM
There was a long thread on this back in June, but no conclusion was reached. I seem to have an even worse version of this problem as when I set mine, the CC immediately accelerates about 10mph over the speed I set, then begins to fluctuate. Not good for avoiding tickets, which is why I use it. Help would be greatly appreciated! The first step I want to take in diagnosing this is to substitute the control unit from a working system ... any local volunteers? :)
Hot77911 10-10-2003 10:28 PM
Wish I could help. My recent 84 serches up and down constantly. I will get this figured out.
Speedy1 10-10-2003 11:47 PM
ups and downs
Yea I'd like to know also my 82 turns on accels then drops 10 mph then accels to set limit then cycles all over again drives me nuts at begining of summer I had all vacume lines replacesd including air box injecters replaced and all re sealed I thought this was going to fix this prolblem amoungst the other issues but it did not. Still perplexed :confused:
