European Pistons and Cylinders
Has any used 3.0 litre European pistons and cylinders on a 911 SC rebuild?
I've been told that they are higher in compression, and will thus give more HP, without making radical changes in anything else.
Advantages and disadvantages? Thanks.
Old 10-03-2003, 09:12 AM
nice doggie
Hetmann's Avatar
I used euro P&Cs for my rebuild. My impression is that the car is peppier. I don't have definative HP figures. If you need P&Cs anyway you might as well go euro.
Jerry
78 SC hotrod
02 Mini Cooper S
Old 10-03-2003, 10:41 AM
I had Euro piston/cylinders installed one year ago on my "87 Carerra and am pleased with the result. I also had a 964 cam installed and the chip remapped. End result was 245 hp on the dyno, more torque and better performance all around. Would do it again in a heartbeat. You must use premium fuel if you go with the higher compression Euro p/c's.
Old 10-03-2003, 10:56 AM
