-   -   The widest tires I can put on 15" Fuchs (http://forums.pelicanparts.com/porsche-911-technical-forum/130068-widest-tires-i-can-put-15-fuchs.html)
stone43 10-03-2003 01:33 PM
Don't start flaming--I did a lengthy search.
It is tire time. I want to put the widest tires possible on my 7/8 X15 Fuchs.
I have:
Front: 205/55-15
Rear: 225/60-15
What is the widest tire I can put on without it looking stupid or needing modification?
I found some BF Goodrich 245/60-15 (rear) and 225/60-15 for the front at Tire Rack. Still looking for additional options.
If those don't work, perhaps I will be stuck with the Yokohama AVS ES100 everyone seems to like, but they only go to 225 for 15's. Perhaps those with a small spacer?
Pictures are always appreciated by someone who has actually done it and lived to tell about it.
Chuck Moreland 10-03-2003 02:24 PM
What tires do you have now? I've been looking for those sizes, so far without success.
stone43 10-03-2003 02:27 PM
Pirelli P6000 on the front, Bridgestone Turanza on the back. They came with the car. I hate mismatched tires, but they were in good shape, so I have left them on.
Schrup 10-03-2003 02:55 PM
I just put the Yokohamas on 205/55 front 225/50 rear, here is a picture of what it looks like & another of a photoshop of it lowered. I hope to lower it this winter.
http://forums.pelicanparts.com/uploa...1065221629.jpg http://forums.pelicanparts.com/uploa...1065221639.jpg
Drago 10-03-2003 03:16 PM
My God man!
That upper shot looks like a freakin' dune buggy! :D
Thou shalt be banish to Gruppe B for such ride height violations ;)
J/K Paul...
Schrup 10-03-2003 03:21 PM
That's ok it's one fast frickin dune buggy. :D
pwd72s 10-03-2003 04:49 PM
You may want to carefully measure the clearances you have with your current tires. Then, play around a bit here:
http://www.miata.net/garage/tirecalc.html
Alan Cottrill 10-03-2003 06:25 PM
Paul, when you went with the smaller tires did your seat of the pants dyno notice a increase in low end torque?
Schrup 10-03-2003 06:40 PM
Alan, I did notice a bit, but I also had set my timing after a tune up. The car absolutely hauls butt. Next week I get to change my front wheel bearings, passengerside is getting pretty loud, especially around right turns.
stone43 10-03-2003 07:17 PM
Anyone have a shot from the rear or back. My biggest concern is filling out the wheel well to the max.
Rouxzy 10-03-2003 07:23 PM
I've been running 225/50ZR15 on the back of mine. They need replacing for next season. I've been searching and I think the time is due to upgrade to 17". Good 15" selection is getting harder and harder to find.
Tom
Russ in VA 10-03-2003 08:26 PM
From our good friends at the tirerack.com
Dunlop SP Sport 8000 (Ultra High Performance Summer)
ZR Speed Rated Price: $127
Estimated Availability: In Stock
Schrup 10-03-2003 09:34 PM
I was trying to track down those Dunlops about a month ago & everyone (including Tire Rack) said they were on back order & the factory didn't know when they were going to make a new batch.
jess p 10-04-2003 11:14 AM
widest tire
On an 8 inch width rim you can fit a 255 series tire. That is the
widest you can go safely. The problem is finding a 15 inch tire
in those specs. Not many tire companies are making tires for
15 inch rims.
76 911S
66 912 V8
66 912 2.2 WITH NITROUS
