MOMO3.2's Avatar
Fluttering lights on 87 Carrera
I have had my 1987 Carrera for 3 months. I just noticed a couple days ago that my parking lights were flickering or fluttering. Upon further investigation (duh) my headlights and dashboard lights do the same thing. It is not a radical high/low flicker, it is just a constant little flutter. There is also no real change when RPM's are increased.
I am sure this is not normal. Could this be my VR??? Can I make a conclusive diagnosis by using a voltage meter? Do I need to change this thing out ASAP? My Carrera is my daily driver. Help!
Thank you.
Mike
P.S.
I did a search and I know there is a SIMILAR post. My car's flicker/flutter is different than the "bright/dim" on the other post.
Old 10-04-2003, 09:42 AM
Driving member
jester911's Avatar
Could be a bad ground, or possibly bad alternator. I would check the ground first.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 10-04-2003, 09:58 AM
Early_S_Man's Avatar
Porsche Crest
Mike,
You should be able to tell if the problem is alternator-related with a multimeter. A DMM probably will give constantly changing readings that are hard to read, while an analog multimeter will show fluctuating needle readings around a certain central range on the scale. If the Voltage fluctuation shows up at the 12 Volt accessory outlet during a test run while an assistant monitors the system Voltage level ... then it seems likely that either a major system ground -- such as transaxle-to-body, or battery ground strap would have to be causing the problem ... or your Voltage regulator is going bad.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-04-2003, 10:11 AM
