Hey dd, although i don't know when i could dyno i am going to install headers, not ssi's, on my sc. That's the advantage to only having winter for 2 months of the year. :D
I have not had mine on a dyno yet but I would expect similar numbers to Jack's car since: - I run the same engine type and chip - I run 993 headers with high-flow mufflers (free flowing) - I smoke MikeZ's car since his is a little heavier It would be very instersting to have all the 964's with the same chip but different exhaust setups on a dyno the same day. We currently have B&B (Jack), headers/supertraps(Mike) and 993HE/glasspack (me). I belive they'll all be very similar powerwise. On a dyno it comes down to gearing. On the road in a straight line performance it'll be tires and weight. On the track Jack's car in a whole different story for all the suspension he has and his track experience.... ingo |
We never made any HP claims...we wanted to see what "others" found first....thanks to Jack. We will not make ANY claims. If you don't like it send it back.... |
The opening of the BBRII video has a sound clip of my 3.6 with dual supertrapps, headers and the chip.....Surflvr should be able to send that to you....
surflvr, can you send it? :-)
Hi also uses the 964 heat exchangers and pre-964 cam sprockets. Claimed horsepower is 305hp and 282 ft/lb. -Chris |
The vram in and of itself does not add much hp. It does allow the torque peak to be spread over a wider rev band.
For ultimate power, albeit over a narrow band, , the plastic manifolds are second best to individualy throttled manifolds like the factory Cup(Thielert Injection), RSR and TWM intakes. The problem w/ making ultimate power lays more w/ the cams which are limited by the metering mechanism connected to the manifolds. The vram is a device best suited to a street car for combination street/DE, There are better ways to go for an all out race car. The 993 cam drive is a unique arrangement which needs to be backdated to use any of the hotter cams. |
Ninemeister replaces the VRam with 964 plastic intake because he believes "in practice it restricts breathing of of the engine at higher revs"
Hi also uses the 964 heat exchangers and pre-964 cam sprockets. Claimed horsepower is 305hp and 282 ft/lb. Go have a look at their site. They don't exactly stop there. I think they junk the whole airflow measuring system and run a MoTeC EFI using Alpha-N (throttle position and RPM) only. Link to package Description of what they do |
Thanks, Tom |
Thanks, but he isn't talking about Imagine Auto, but a "gentleman in Lousiana".
Tom |
Hi Tom - Blown is correct - the CIS guy only works through distributors so Stephen at Imagine Auto is who I worked with on this. You can e-mail him at porschephd@imagineauto.com - tell him Bill Bennett mentioned the CIS fuel head rebuild to you and Iam sure he will take it from there. I would be interested ot see what results the SC fuel head gets.
When you guys say "fuel head", do you mean the fuel distributor?
-Chris |
I think the Motec article was to do with the tuning of a 964RS rather than the guy that did the engine transplant.
My apologies - you guys are right (and I was thinking of a different article in the same magazine about their 964RS plus). I dug around their site a bit more and found what looks like the article you guys are referring to:
The right article, I was wrong! |
As we all should know, ignition and fuel map data stored in Eproms,
flash devices, and microcontrollers used in Porsche Motronic systems are copyrighted material controlled by Porsche A.G. Just ask AMD about copyrighted microcode when they were sued by Intel over 386 and 486 math coprocessors. These guys who sell performance chips are potentially liable for copyright infringement, since they all use the basic Porsche microcode and make minor alterations and resell it as their own code in the performance chips. It's the same as if someone changed a couple of pages in the "Porsche 911 Carrera" manual by Bentley Publishers and reprinted and sold it under a different name. In either case, a microcode or a book, it's an expression of one's work and as such protected by copyright law. As you may have noticed, performance chip guys don't acknowledge use of Porsche's copyrighted material in their literature nor on their websites. But again, may be Porsche has little concern about the copyright abuse, since they probably look forward to selling a lot of Porsche parts the result of damaged engines. Have Fun Loren '88 3.2 |
| All times are GMT -8. The time now is 06:01 PM. |
