moazam's Avatar
Send a message via AIM to moazam
Brake pads with no sensors?
I ordered the front brake pads from Pelican, but it looks like I may have ordered the wrong thing now.
The ones I ordered did not have an area to attach the brake sensors. I ended up putting the brake pads in anyways and just zip-tied the sensor wire to be out of the way.
Is this OK? If it is, I'll just run these pads for a while and order the correct ones next time.
I ordered:
C-351-950-02 911 Steel A Caliper Front Brake Pads (late 1975-83)
These are actually listed in the catalog as:
OEM Front Brake Pad Set, Steel 'A' Caliper, 911 (late 1975-89), From VIN# 911-520-2046 (Coupe), 911-521-1218 (Targa), 911-540-0342 (Carrera Coupe), 911-541-0148 (Carrera Targa)
2014 Porsche Cayman S
2001 BMW 525i Touring
1996 Porsche 911 (Gone to Germany)
'86 911 Carrera (Gone to Aruba)
Old 10-04-2003, 07:37 PM
Early_S_Man's Avatar
Porsche Crest
M-
There is no reason I can think of to need the sensors in the first place -- for a competent owner ... so why even bother replacing the pads you have now??? The 'S,' 'A,' and wide-A pads can be used interchangeably. A Ty-rap sounds like a good solution ... though cutting off the wiring at the firewall could save a few grams!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-04-2003, 08:39 PM
moazam's Avatar
Originally posted by Early_S_Man
M-
Sounds good. I'll leave them as they are, they should last me a while.
Old 10-04-2003, 09:03 PM
