1978 distributor
Recently my distributor failed. The shaft moves up and down. At Wayne's suggestion, I would like to replace the shaft bearing and hope this fixes the problem. ( the rotor clipped the caps lugs so we knew we had movement)
If not, I would like to buy a rebuilt distributor or a good used one.
The distributor must have the numbers 0237306001 cc to work in my 1978 911sc.
Old 10-06-2003, 01:59 PM
you could always drive the pin out of the gear and inspect it for what wore out. often a fibre washer goes away, creating plenty of up/down movement. the 78/79 units are obsolete now, replaced with the later SC units with the dual advance. not quite the same advance curve.
206 637 4071
Old 10-06-2003, 02:02 PM
