Current drain and door switch
You've heard this story before. My battery drains after a few days of sitting. The battery is good and the alternator is charging. After reading a number of posts on the subject of current drain and shorts, I decided to look at the door switch (while my battery was charging), before going through the diagnostic procedure with the ampmeter and fuses. I removed the drivers-side door switch carefully. I held the center post stationary so I would not twist and break wires. Well, there were no wires attached, so I guess something happened quite a while ago with the previous owner. My problem now, is that I can not locate the wires after fishing around etc. Is there any other access other than through the switch hole? Any suggestions would be appreciated.
Chuck
1987 911 Targa
1962 C182
"Dirt is permanent. You can move it around, but you can never destroy it."
Old 10-06-2003, 03:01 PM
