Call me crazy 3.2 Turbo
Hi Guys, well after 9 months of search for a bolt on turbo kit, I have decided to build one with the help of the best Porsche BBS.
I have a ?, trying to get my parts list together.
I will be building single turbo, low boost, no intercooler, no internal mods.
Parts list so Far
* Garret t04
* Wastegate the ? do I need to run a 40 mm waste gate or can I use a 38 mm
More Questions coming soon
Thanks Guys
Old 10-06-2003, 12:03 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Talk to juan. He has a really bad a$$ 3.2 turbo making 600+ HP out of stock motronic injection.
edit: do a search on HP junkie and you'll find him.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 10-06-2003, 12:05 PM
Also, the guys at www.imagineauto.com might be able to help.
Old 10-06-2003, 12:35 PM
Yerman,
There are quite a few parts to add. To start you have to specify which trim you want your turbo in. There are many specs such as Turbine pitch, compressor housing size, AR, etc etc. There are probably a 50 variations of a T04.
The wastegate would most likely be a 40mm....Tial is a good brand. You'll have to use the appropraite spring to work at the appropriate pressure.
You'll need a rising rate fuel regulator to provide the proper amount of fuel.
A custom chip to tie all the new equipment together. Where will you get one? From what I understand Protomotive no longer sells the chip alone.
All the custom piping, including flanges, exhaust-to-turbo, intake/air cleaner, muffler etc etc.
Plumbing/fabrication to deliver oil to and from the turbo.
While you're here you might as well go for the intercooler...why stop now?
Then it will need to be tuned...by someone who knows what they're doing....or your car is kaput.
Understand that I am not trying to discourage you. However, this is a complex undertaking. It took many years of trial and error to make a reliable system for this car and by people who were experienced engineers.
Warren & Ron, may you rest in Peace.
Old 10-06-2003, 12:47 PM
I know what your saying and talking about im just talking about the wastegate will a tial 38mm wastegate work and what type of garret t04
how about a to4B18
Williamknightperformance.com
Perfectpower.com
Old 10-06-2003, 01:12 PM
ValveFloat's Avatar
Just an opinion, although not just mine, an intercooler should be included.
You could save your self some work and $ by going with a turbo with an internal wastegate. I have personal experience with an Escort Cosworth making 270AWHp from a 2.0L with an internal wastegate, so I don't think you would be giving up much. You would certainly gain more from teh intercooler than you would lose with an internal waste gate.
$.02
Joe
1993 C2
Old 10-06-2003, 01:15 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
You'll have to calculate your cars theoretical cmf intake on boost and what pressure you'll run it at. Those two define what compressor housing to use (you'll know what i'm talking about once you've seen a compressor map) and the turbine AR ratio just tells you what speed the turbine will spool given the size (larger more lag, smaller less lag but more back pressure and therefore heat). As far as the waistgate, 40mm is a bit big since your not running high boost, but too big a waistgate really doesn't hurt, too small and now you've got some problems.
If i were you, i'd find another turbo, most of the t04's are meant to run in the .8 or more boost range with decent amount of cfm behind them. A t3/4 hybrid might be what you want to look for.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 10-06-2003, 02:30 PM
If you don't have it, buy the book
Maximum Boost by Corkey Bell
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 10-06-2003, 06:45 PM
