Convertible top HELP!!!
HELP!! please, Do I missing something for this installation Convertible top. I think I got TARGA (not sure) 3 hole line up on
body. This car was with TOP before stolen, and I bought all parts to made it a live again. HELP PLEASE !!! New911junior o o o o o o Hole on car's body Hole on convertible bas braket
Bob Chavalit |
Come again ??
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
i think im missing something....
Past: 04 Anniversary 911 #0895, 82 911 SC, 88 Signature Series Carrera, 88 911 Turbo Cab, 73 911T, 63 356B, 06 Cayenne |
Dept store Quartermaster
Yes, a common issue for sure. Just do a search for "3 hole line up" and you will see that this has been covered many times and with great detail including diagrams and install tips.
Sorry couldn't resist
Cornpoppin' Pony Soldier |
What?
lendaddy, you made me look! LOL!!
Tom J. 911SC Cab SCWDP CaymanS |
Add PIX
New911junior
Bob Chavalit |
To lendaddy
search for "3 hole line up" I go for "hole line up" can not put #3 in there. Anyway can't get any INFO yet. Look like I have to cut the body and get new foldinf top base to put on it. Parts: 911 501 431 60 - folding top base - L 911 501 432 60 - folding top base - R 911 501 465 60 - insert - L 911 501 466 60 - insert - R http://vintagebus.com/howto/cab/ I'm not understand, if this car was have CONV TOP before (per his pix) and I can not put a new(used top) on it ? New911junior
Bob Chavalit |
To lendaddy
search for "3 hole line up" I go for "hole line up" can not put #3 in there. Anyway can't get any INFO yet. Look like I have to cut the body and get new folding top base to put on it. Parts: 911 501 431 60 - folding top base - L 911 501 432 60 - folding top base - R 911 501 465 60 - insert - L 911 501 466 60 - insert - R http://vintagebus.com/howto/cab/ I'm not understand, if this car was have CONV TOP before (per his pix) and I can not put a new(used top) on it ? New911junior
Bob Chavalit |
That does not look like a convertable top bodyshell you are trying to fit the roof too. But I am just as confused as everyone else.
David Cayenne Turbo - Cargraphic Stage 2 Power kit, lowering module 997 C4 Cabriolet - Basalt Black 86 Turbo Body 911 Cab - Many Mods Gone and Missed: 97 993TT: PSS9, CarGraphic Exhaust Last edited by DJB; 07-17-2003 at 03:57 AM.. |
MBruns for President
Looks like a converted Targa to me - post the vin# and I am sure someone can tell you if the car started out as a convertible or is a converted Targa.
From there you can tell if you will have to modify - or just use straight factory parts. My guess is that it started out as a Targa - the bar was cut off - Is that what you are looking for?
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
VIn # 9114112715
74 body 76 2.7 engin Thanks everyone New911junior
Bob Chavalit |
My pix, white stub in door is wax.
new911junior
Bob Chavalit |
Well, there you have it - no Cabs in 1974 so this is a conversion.
You will have to drill more in the body - or drill in the cab frame to make it fit - pick your poison.
Hi Jeremy Dixon ;
I can make it fit, 1 hole 1 bolt per side to hold TOP and body, but window frame is off set about 1/2". And I need to push TOP down about 1/2" also. Thanks again. New911junior
Bob Chavalit |
Let's back up a minute.
You have a '74 cab conversion. From what I'm able to piece together, you bought this baby without a top. Then you went out and bought a top, and now you're trying to install it? Right? From where I'm standing, that doesn't look like a standard cab mount. Who knows what in the heck it was, but it doesn't look like any of the mounts I've seen, and I did a far bit of research before I broke out the sawzall on mine. If the previous supposition is correct - that you bought it sans top, then I'll break out another conspiracy theory that the top wasn't actually stolen, but it was some abortive aftermarket cab conversion, which is why your stock top doesn't line up. Check out my cab conversion page for detailed pix of what the pieces should look like: http://vintagebus.com/howto/cab/ The first thing I see is that your mount is not recessed where the top bolts on, which would explain the fact that you're 1/2" too high. In addition, does the latch mechanism match the windshield header? You're bent over double if they sold you an 86-> top - it won't fit on your door posts nor will it match the header. If I'm right up to this point, I have an exit strategy for you: I have an extra set of orginal top mounts - they're the ones shown on the page - that you could weld in, and then you can use the stock top. ![]()
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Thom
Top fit perfect. The last owner told me, I need TOP C2 to fit this baby. That all I know, and got TOP from Silverstar junkyard in Sacramento last Feb 03. If the previous supposition is correct - that you bought it sans top, then I'll break out another conspiracy theory that the top wasn't actually stolen, but it was some abortive aftermarket cab conversion, which is why your stock top doesn't line up. <<<< You right .. And I saw that PIX from that Web. If I'm right up to this point, I have an exit strategy for you: I have an extra set of orginal top mounts - they're the ones shown on the page - that you could weld in, and then you can use the stock top. Wonder how much do you want for that top mounts ?? Also looking for 2 1/2" wheel spacer. Hope to get a car run on the street next month. New911junior
Bob Chavalit |
Before we go any further, have you validated that the top that you have will latch into the car's windshield? If it will<<< YES, latch and lock good.
Only problem I got is ,I have to push hard to align that pin into slot. New911junior
Bob Chavalit |
Thom to the rescue! Thanks also for the pictures on your website of the wheel bearing replacement. Helped - even without text. My brake rotor/pads/caliper/lines went without a hitch.
