Bosch vs. NGK
Opinions please on spark plugs for '87 Carrera. Bosch or NGK? I see Pelican has the new Bosch +4's....does anyone have opinion on these?
Thanks!!!!
Old 10-07-2003, 06:35 PM
Senior Member
Doug Zielke's Avatar
Both good.
I use plain vanilla Bosch coppers. Platinum (and other 'trick') plugs are not needed. With the cheap Bosch or NGK's, you can replace them every year and maintain top performance.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 10-07-2003, 06:44 PM
i want one of those...
Rufblackbird's Avatar
Location: formerly a grass shack in Hawaii, now Peoria, AZ
I'm a firm believer in Bosch for German cars. NGK's for Japanese cars. Even though I've had success with the Bosch +4s (not in a German car), I have read about many instances where a car runs rough or will not run at all after they are installed. Like Doug said, just buy the cheap copper stuff and replace them as often as you like.
Jeff
'72 911 T Targa widebody VTK #111385 http://www.911vtk.com
Old 10-08-2003, 12:50 AM
BER BER is offline
BER's Avatar
I have been using plain NGK copper plugs in my '84 Carrera with no problems. I replace them annually. They are under $2 per plug, so the price is right.
In the past, I used Bosch coppers and they worked fine also. As others have said, the designer "trick" plugs are not needed in the 3.2 Carreras.
Bruce
Old 10-08-2003, 04:58 AM
JC930's Avatar
Spark plugs are like girls, we like the ones that sell themselves the best.
jc930
77' 930 turbo carrera silver SOLD
03' SL500 Mercedes Benz white
06' GMC Yukon Danali white
15' LTZ Chevy Suburban black
07' 997 tt black
Old 10-08-2003, 05:48 AM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
Stuck Plus 2's in mine, had flat spots all they way through the RPM range. Tried the Plus 4's, same thing. Got better over time, but never totally went away. Went back to the stock Bosch plugs, problem solved, ran beautifully.
IMHO, +2 +4 aren't worth the money.
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 10-08-2003, 05:30 PM
