964 Rear Glass Install in 78 Coupe
I am updating my 78 coupe with 964 glass and seals. Have installed the side windows w\o problem. The 964 quarter windows went in today with 993 seals w\o problem. I have a 964 rear glass .... and problem. The installer believes the rear glass is too long by .5 inch. I am using a 964 rear window seal. Has anyone installed a 964 rear window glass [mine has 3rd brake light and defroster] in a 1978 Porsche 930 coupe?
I have a 964 windshield on order and plan to use 964 factory seal.
Garrick S. Lew
600 Townsend Street, Ste 329E
San Francisco, CA 94103
gsl@defendergroup.com
Old 04-30-2003, 12:59 PM
Series900's Avatar
I can offer this , the factory metal template for window apertures is the same from 65 911's thru the 964 series, so it would seem logical that as long as you use the correct glass /rubber combo you will be able to update and back date. The 964 glass will be larger , but it also sits higher in the opening to gain a flush fit to the surface.
Damon @ SERIES 900
Sunapee NH
Damon @ SERIES 900.com
Sunapee NH
several 911 variants
Old 04-30-2003, 08:57 PM
Series 900 ... thanks. I will post on the success or failure of the install.
Garrick S. Lew
Old 04-30-2003, 09:24 PM
skinnerd's Avatar
please do post your success or not
I would be interested in what you find out
thanks
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 04-30-2003, 09:29 PM
A professional glass guy has been handed the task of the install and I will report back with the results. Last thing I want to do is break or crack it doing it myself.
Garrick S. Lew
Old 04-30-2003, 09:37 PM
CBRacerX's Avatar
Did this ever work out?
Old 10-10-2003, 06:52 AM
Sorry ..... forgot to report back. The rear glass went in fine and fits fine. The problem was that I had a 911 rear glass seal which does not work. Once I got a factory 964 rear glass seal it worked perfectly.
Garrick S. Lew
Old 10-10-2003, 07:34 AM
CBRacerX's Avatar
Excellent! I did this on a 73 using a lexan rear window and that went well also.
Chris
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 10-10-2003, 11:00 AM
