-   -   Seal Around Rear Quarter Windows (http://forums.pelicanparts.com/porsche-911-technical-forum/131159-seal-around-rear-quarter-windows.html)
NickB 10-11-2003 01:48 PM
I'm installing rear quarter windows and I have a question about the installation. I understand there is no weatherstrip adhesive on the outside part of the black seal where it contacts the car body but should I put weatherstrip adhesive where the chrome window frame sits in the inside part of the black seal?
It seems like I should but I want to check with everybody first.
Thanks,
nick
1970 911 E (restoring)
john70t 10-11-2003 10:00 PM
The seal fit is very tight-about an hour per and sore thumbs to install- so it should not need it and the half dried glue will make high spots. Do the flat side first and roll the bead into the groove, have fun.
CarreraS2 10-11-2003 10:04 PM
No glue.
sithot 10-11-2003 10:17 PM
Inner seals (glass) are easy. The outers are at least worth a pair of sore thumbs. No glue, no weatherstrip adhesive and no silicone.
Tom
Shaun @ Tru6 10-11-2003 10:21 PM
no glue.
I wrapped mine around as best I could, then let sit in very hot water in the tub for an hour (I am not married) and then a hair dryer made the job quite easy.
DonDavis 08-16-2004 11:11 PM
Any new "tricks" on this task? I just spent about an hour and got half way on ONE window. My thumbs and fingers are toast.
I'm using a small Orangewood stick to help roll the seam into the groove approx half-inch at a time. Thought about using a little dish soap but I just know that would turn bad.
I can see it know...."Almost there...a little more to go.... just about done...." and then the window would slip out of my soapy hands and crash to the garage floor, shattering. That would cost me a LOT of beer. You know, for the anger/sadness treatment.
So, if anyone has any "Best Practice" tips, I would appreciate it.
RoninLB 08-16-2004 11:16 PM
do a search.
some 1/4 are different than others. I think JW did some good posts on this a while ago.
DonDavis 08-16-2004 11:33 PM
Ron....dude... I did do a search. That's how I found this old one. At least I didn't start a new thread. Some older ones said "Yep, that gasket sucks. Sore thumbs, but you will get it" or several threads about the fixed 1/4 windows and the cord trick.
Now, either help with my windows or post some hot chick pics! Or sumpthin'!:D
When's your next BIG ride?SmileWavy
Shaun @ Tru6 08-17-2004 04:34 AM
Did you read through this thread? :p
Really, it was pretty easy after soaking in hot water. I can add that that a small screwdriver helps feed in the molding.
DonDavis 08-17-2004 08:15 AM
Shaun, I was wondering if you put the whole window or just the gasket in the water. Sounds like you put the whole window. I would think that if it were just the gasket then it would cool before you could get finished.
Also, I don't trust myself with a screwdriver for this task. I'm using an orangewood stick.
Thanks.
Shaun @ Tru6 08-17-2004 10:55 AM
Don, definitely put the whole thing in hot water, yes, a screwdriver means you have to be be very careful. I took the slightest edge off the corners with a grinder, and it worked great. Just be very careful and "feel" the rubber.
RoninLB 08-17-2004 03:49 PM
Ron....dude... Now, either help with my windows or post some hot chick pics! Or sumpthin'!:D
My ride has been just transformed. I'm tweaking now and will do a few 2-10 day rides to feel it out. If it can'r roll for at Least 10k miles, it's not tweaked enough.
hot chicks.. for fair and balanced reporting eyeball this babe.
http://forums.pelicanparts.com/uploa...1092782946.jpg
RoninLB 08-17-2004 03:55 PM
don't miss the crack.
http://forums.pelicanparts.com/uploa...1092783344.jpg
rattlsnak 08-17-2004 04:40 PM
i used soapy water, it still was a pain, but it worked.
<<-- i bet the girl above sets off the metal detectors at the airport!
RoninLB 08-17-2004 11:09 PM
http://www.pelicanparts.com/support/smileys/gitaar.gif
http://forums.pelicanparts.com/uploa...1092809343.jpg
DonDavis 08-17-2004 11:34 PM
Butthead voice- huh-huh-huh-huh-huh
RoninLB 08-18-2004 04:27 AM
they get $200 each.
Shaun @ Tru6 08-18-2004 04:30 AM
they get $200 each.
I've got 2 early fenders in good condition (although not as good theirs!) but do you think they'd be interested in a trade?
RoninLB 08-18-2004 04:38 AM
I could ask them. They seem to be very receptive females. Maybe if I can explain how stiff the times are now-a-days.
