Is there an easy tip for reconnecting the feed lines when replacing the master cylinder?
Is it better to leave the rubber boots in the cylinder and feed the lines in or put the boots on the lines and feed them both into the master cylinder? This has to be an easy part of the job but I'm stuck. Thanks guys,
Fritz 1987 944S 1973 911E Last edited by Fritz; 10-12-2003 at 10:00 AM.. |
The first one and lube the fittings with brake lube before you fit them. And they can give you fits
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
I finally ended up disconnecting the lines up at the resovoir and pulling them out the bottom of the car. I then easily connected them to the m/c by tipping them & the grommets, then threaded the lines + m/c together up through the footwell & into the trunk.
It was simple that way. --Mike |
Navin Johnson
Mike figured it out... do it his way
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Kolibri
Yes, just finished this project, using this same advice, and it worked like a charm. I don't know how long it would have taken me to try and hook those blasted grommets up.
Michael
1942 VW Kübelwagen 1940 Zündapp KS 600 1941 Zündapp KS 750 1975 Volvo C303 TGBII 1967 Honda S90, 1975 CB550 |
