Well, the T-bars, adjustable springplates, Netrix bushings, and Turbo tie rods are in!
I would like to thank Chuck Moreland for answering all the stupid questions I asked him while I was doing the install !!!!!!!!!!!!!!!!!!! Thanks Chuck. As for the stat junkies, here you go.... With 144 lbs in the seat (although I only weigh 132) and a full tank of gas. Corner weights: 540/519 778/754 Total 2590 lbs. (-144lbs they had in the seat and lots o' gas, I guess it would be around 2,200 lbs!) 1.4 degrees of rake. Front left/Front right: Caster +5.16 / +5.16 Camber -.84 / -.84 Toe +1/32 Rear left/Rear right Camber -.84 / -.84 Toe +1/16 / +1/16 Final height 5 11/16 / 5 3/4 11 1/16 / 11 I'll take some pics this weekend! But, first I have to put my rockers back on. What do you guys think?
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please ![]() Chad aka "Chili" 1974 Base coupe in Carrera outfit. No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.) My car http://www.pelicanparts.com/gallery/CHILI 1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras. |
Certified Pre-Owned
Why did you corner balance with a full tank of gas?
'84 Carrera Coupe |
SCWDP- Shock and Awe Dept
1297/1294 on the diagonals? You’re three pounds off dude, I’d have it redone.
![]() Looks good, I do agree it would have been better w/ a half a tank. Just always keep it full. ![]() You could also go another half a degree negative camber on the rear.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
Well, it wasn't a copletley full tank, I guess. I set ride height with a full tank and then drove to his shop. it was more than 3/4, but less than full.
I usually run it from half to 3/4 on a normal basis. Rides a little nicer and gets better front grip with more than a half a tank.
As for the camber, I told Kevin (GAS Motorsports) that I didn't want to wear my tires out too much. I was thinking around -5 front and -1 rear, but I told him whatever he thinks is best for me. What can I say, the guy wins races over and over and his car has been inspected with a fine tooth comb. So, I respect his opinoin. If I wear out the outsides, then I'll change it. But for now, it sure does look gooooooood! Man, it was way too high before.
Pretty damn close I would say.
If you want to tweak it a little more, you could transfer some weight from the left rear to rt. front. Try cranking the left rear down 1/16 to 1/8", or just leave it alone. It's easier if you have an adjustable height adjuster on the rear though. Sherwood Lee http://members.rennlist.org/911pcars |
Cool, according to Thom's corner balance calculator you are pretty darn close
http://vintagebus.com/cgi-bin/balance.cgi Ideal Corner Weights Left Right Front 538 520 Rear 779 752
TOE
Hi Chili,
did the shop have any trouble getting the toe to zero out (more or less)? I ran out of adjustment in the front and they couldn't get the toe to zero. I will have to slot the front adjustment plates to get zero. just curious. Thanks, Troy
Troy Past: 1975 911S Silver Anniversary-rebuilt and sublime. Past: 1988 Carrera-backdated with a 3.6 and all the goodies. Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's) |
Cool calculator. Didn't know it existed.
Troy, Not sure. They have notes on the print-out that says "maximum camber front = .84 out all the way" and Rear toe set minimum at this minimum neg camber.
Arghhhh !!!!
Diagonals are NOT to be equal for tin-can ( non formula type) cars. See the *many* posts on this if you do a search !!! LF/LR should = RF/RR.... short form answer. ---Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Senior Member
Okay, smartiepants (wink, wink)...how do you get the left side to weigh less and the right side to weigh more, unless you change ride height to be unequal.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
a passenger?
"how do you get the left side to weigh less and the right side to weigh more, unless you change ride height to be unequal."
The entire side? As surflvr911sc mentions, a passenger. A load of bricks or some lead weight will accomplish the same thing. Sherwood |
Chad, Whatever Kevin says, I would stick to it, you have the benefit of him being at the track to make any changes or adjustments he feels necessary. All his competitors know that he squeezes out every bit possible. His car handles great, knows how to manage tire wear, runs very economical.
He spanked them again this weekend. Were you there with Steve and Anders to watch the Saturday Red/Orange fun race? That was good racing! |
