brake fluid leaking from overflow/vent line
I was attending a DE at Mosport 2 weeks ago and noticed that my brake vent hose was leaking fluid onto the drivers side front control arm and the ground after a few sessions on the track. The vent hose runs down in front of the drivers side tire more or less next to the A/C condenser under the front spoiler. The car is a 79 911SC.
Can anyone explain why the vent hose would be draining fluid after a few very hard sessions? The level in the reservoir dropped significantly to about an inch below the low level/add mark. I had never seen it drip before and was wondering if it was possibly caused by the high cornering g-loads getting fluid to slosh into the vent line and later having it stop after the level reached a signifcantly low level in the reservoir? How do other passenger cars vent their systems as I don't see any external hoses and it appears to completely sealed systems? |
Other cars vent directly into the engine compartment, where most other ( front engined) cars have this hardware.
Sure... a combination of high cornering loads and heating up ( expanding) the fluid can case you to push fluid through the overflow line. ---Wil Ferch |
You probably don't have this problem, but thought I'd post anyway as I spent more than a few hours trying to figure this out. I highly recommend you construct some sort of catch bottle for you overflowing fluid as well...it makes a mess underneath the car and others won't be crazy about driving through your brake fluid drips. Good luck- BG |
When I did my first system flush, using the power bleeder, I forgot to block the vent line and put a whole liter of ATE blue on the garage floor. Unfortunately my vent tube was routed to the front of the luggage compartment! What a mess.
I found a small catch bottle that is used to bleed brakes at the local auto parts store and connected the line to it. It has a magnet mounted on it so it’s pretty secure and now I can see when and how much fluid overflows. And it doesn’t get under the car or in the luggage compartment. |
Not sure if these are the same ones that Ryan describes. I got this from Harbor Freight. It's a polyethylene bottle with a round magnet attached to the vented screw top. It's $3.99 and comes with some hose/hose adapters. Bottle holds approx. 2.5 oz.
http://forums.pelicanparts.com/uploa...1066257356.jpg If your fluid loss needs are higher, you can use a bicycle water bottle and cage. Mount it where it won't spill and where you won't be tempted to drink out of it. Sherwood Lee http://members.rennlist.org/911pcars no affiliation with HF, but I wish I was |
That's it! Thanks Sherwood.
Fredmeister,
Does this look familiar? http://forums.pelicanparts.com/showthread.php?s=&threadid=79988&highlight=brake+f luid+leaking Good luck - Dean |
| All times are GMT -8. The time now is 04:45 AM. |
