SSI Heat Exchangers on '70 911S
I am considering adding SSI Heat Exchangers to a stock '70 911S.
Looking for advise, what kind of added horsepower will I get. Does anyone have experience in this area ? |
You will get heat, thats BTU's not HP.
Damon @ SERIES 900.com Sunapee NH several 911 variants |
Friend of Warren
You might see some HP increase, but not much as the stock heat exchangers are pretty free flowing already. The SSI's are equal length headers inside the exchanger and hence some increase, but probably not worth the cost unless your stock exchangers are rusting out.
Kurt V No more Porsches, but a revolving number of motorcycles. |
any recommendation on HP boost.
Jeff R Gruppe #631 Early S Registry # 1825 1973E Coupe |
Friend of Warren
Bruce Anderson addresses this in his Performance book which is at home. If you want I can take a look at it tonight.
RETIRED
SSIs are stainless copies of the units that came stock on your car.
HP increase can come with cam and displacement modifications. When, if ever, has your motor been overhauled?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
