-   -   Any one capable of doing an alignment in Sarasota FL? (http://forums.pelicanparts.com/porsche-911-technical-forum/131834-any-one-capable-doing-alignment-sarasota-fl.html)
byrd101 10-16-2003 12:45 PM
I have a 71T, and have recently rebuilt the suspension. New bushings, tie-rods, ball joints, struts and torsion bars. I’ve added a front sway bar and camber bar. I have the ride height set at 25 1/2” front and 25 ¼” for the rear. Now if only I can find someone capable of doing an alignment. I have taken it to two different shops. The first lowered it (23 1/2” Front and rear) and then said it must have been hit at some point, because they couldn’t get the camber correct. Call me crazy, but I thought the finders rubbing on the rear tires was a dead give away. The tech at the second shop swore up and down “Not a problem we do’em all the time”. Then he airs up the tires to 36psi. During the subsequent conversation I describe the suspension upgrades that had been done. “Ugh, I can check the rear, but I don’t have the tools to make any changes”
JeremyD 10-16-2003 02:02 PM
If it's worth a trip across the big bridge Joe at Germantech does a good job for me - www.germantech.com nice guy too.
nigel911 10-16-2003 04:04 PM
Who did you use? Scottshop recommended D&W tire when I did roughly the same kit out as you, I only had the front end aligned but I do know they can do both ends. 2856 Clark Road, 922 5544.
Is you car a green coupe?
byrd101 10-16-2003 06:27 PM
No,white. Thanks for the tip.
JeremyD 10-16-2003 07:37 PM
byrd101 - PM me your email and I'll make sure to add you to our email list. When we have another get together you and Nigel can caravan over. Maybe you can print out the directions!
nigel911 10-17-2003 02:51 PM
Jeremy, I believe you are truly evil.
All this time since your move across the pond and you still haven't lost your sense of humour...
jenpm 10-17-2003 05:23 PM
Armond of Eurosport in Cape Coral. His specialty is Porsche. He can help you out.
JeremyD 10-17-2003 06:22 PM
Hey, there's Nigel... there he goes.........................
