factory alignment specs for 71 911 T?
What is the factory alignment specs for a 1971 911 T? I have found quite a few recommendations, but not the factory specs.
My spec book will be here about Tues according to Pelican. In my factory workshop manual it has the specs for like '68.
The settings are the same for T,E & S and they are very conservative. The supplements actually call for less neg camber on the rear. Here's what it says in one section: Camber, front.......0 deg +- 20' Camber, rear.......-1 deg +- 15' Toe -in, front........+ 15' to +20' each wheel Toe -in,rear..........0 In another section it say that there should be 0 front toe and +10' rear, but with less neg rear camber, like -50' +- 20' |
Thanks, I’m getting it aligned this morning. The shop called back after I made the appointment and said their system didn’t have specs as far back as 1971.
| All times are GMT -8. The time now is 09:26 PM. |
