Rocker Dent
I'm looking at a 80 Targa and all looks good (i'm getting visions of wonderful things in my head) but there is a good sized dent in the rocker panel on the one side. Anything I should be worried about? Any way to check to see that it's not going to be an issue?
Thanks in advance guys! Adam
1978 911SC 3.0 (former) a_roseneck@hotmail.com |
Not Quite Banned
Pull the trim strip and the panel and see if it went into the body. The panel can be fixed.
Good to see you back - it has been some time!
Thomas Owen 1972 911T 1972 911S |
Binge User
Do you know if it was from bad jack action?
Paul |
Not sure, car isn't local, I'll ask though. Thanks, its great to be back... finally have some funds to play with. (not much but i'll make the best of it
)Adam
1978 911SC 3.0 (former) a_roseneck@hotmail.com Last edited by atr911; 10-28-2003 at 05:40 PM.. |
An easy fix, remove the end caps, slide the rubber bumper strip off, remove the 3 mounting bolts and the entire length should come off. The paint if it is the original paint was painted over a resilient(rubberized) coating at the factory. If the dent is fairly minor, it can be simply pushed out from behind with a flat body hammer over a hunk of wood and not require any repainting. This is also a good time to hose off any dirt in the oil cooling lines if it's the passenger side you are doing.
Harlan Chinn Pacific Northwest Region 1998 Carrera S ArcticSilverMetallic 1982 911SC PazificBlauMetallic |
