Friend of Warren
Heads and Cylinders Off: Things could be worse
Well I started my engine rebuild due to cylinder #5 having 60lbs of compression and a 100% leakdown with air escaping into the exhaust. I suspected at the least a problem with #5 exhaust valve. Well after my battle with the rocker arm and eating some lunch I attacked the heads and cylinders. With the exception of #5 all the valves looked like this:
And then here we have #5. See anything unusual?
But look at the cylinder, perfect condition. The cylinder still shows the factory hone marks after 133,000 miles!
The piston and rings looked ok too.
Kurt V
Old 10-18-2003, 06:58 PM
Sonic dB's Avatar
Wow. Its Pac Man. Looks like you did your rebuild at the right time, sorta preventative maintance in a way.
Old 10-18-2003, 07:05 PM
Friend of Warren
Sonic I wasn't even going to do my rebuild for another 3-4 months. I just got the leakdown tester and thought I would give it a try. Who knows how much longer before that valve broke up and trashed the piston and cylinder!
Kurt V
Old 10-18-2003, 07:19 PM
makaio's Avatar
Good catch Kurt! What would cause that, too tight of valve lash?
Old 10-18-2003, 07:42 PM
Elombard's Avatar
I am curious, I have a similar situation on #6 in my SC motor. Did it run well? My car runs great.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 10-18-2003, 08:03 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Kurt,
How did the plug look on #5. Looks like it could have been caused by excessive heat from either 1) a very lean mix in that cylinder or 2) the valve not seating against its seat correctly thus not dissipating its heat into the head.
Good catch BTW!!
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 10-18-2003, 09:43 PM
Friend of Warren
In my case it was a very worn out valve guide. The valve is cooled by transferance of heat to the valve guide. When the guide is worn out the heat isn't transferred and the valve burns and cracks and ultimately breaks.
Kurt V
Old 10-19-2003, 08:17 AM
Friend of Warren
Same here, my engine was running great, or so I thought. Good idle and accelleration. Last month I took it on a 1000 mile drive with no problem. Guess I was just lucky. Valve could have broken up and trashed a piston and cylinder!
Kurt V
Old 10-19-2003, 08:21 AM
Senior Member
Doug Zielke's Avatar
Classic!!
I've been looking for that exact shot (burned valve) for the Mechanical Mayhem Files.
Thanx, Kurt.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 10-19-2003, 08:27 AM
Good to see it didnt completely fail, trashing that cylinder. One little tip, as I noticed you labeled that head with a sharpie, make sure to engrave the cylinder number etc. since that sharpie marking will most likely be worn off with cleaning.
Are you gonna tear into the bottom end?
Chris
Old 10-19-2003, 08:32 AM
Friend of Warren
Chris
Yep, this engine is going down to the bare case halves!
Kurt V
Old 10-19-2003, 03:15 PM
norustscott's Avatar
You have to love that little voice in the back if you head...no the other one that says, stop, do not pass go, tear down before it gets really expensive...great call.
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 10-19-2003, 04:48 PM
