Lighting problem - Odd
Any thoughts are appreciated...
Car is an 87 carerra, first problem started with a fast blinker on the pass side. Pass side front light is not working.. no power to the socket or wires. Today, headlights go out (I have relays installed). odd thing is only the low beams. I also don't have any running lights or dash lights. I do however have the lights on the HVAC system that come on when the headlight switch is turned on. I pulled the headlight switch and have 12 volts on most wires when the headlights are supposed to be on. Could it be ignition switch?? Directional stalk unit?? Also, I'm in desparate need of the lighting circuit diagrams.. anybody have a scanned copy?? smatre@carolina.rr.com Thanks!!!!!!!!! |
Bad turn signal switch. Happens all the time.
| All times are GMT -8. The time now is 01:06 AM. |
