Emergency Flasher Switch not Lighting
Just noticed a funny situation with my emergency flasher switch:
1. Push in on the flasher switch, and the exterior flashers flash, except for the left front.
2. The bulb in the switch will not flash; replaced the bulb, and still no flash.
Logic tells me to replace the bulb in the left front, and see if that cures all. However, prior to getting to it this weekend, does anyone know if the switch bulb will not flash if one of the four flasher bulbs is out?
TIA..................Andras
Old 10-20-2003, 05:38 AM
