Help w/correct way to remove this Blaupunkt(pic)!
Guys,
What is the correct method for removing this factory Blaupunkt. As you can see each side has 2 small holes at the top and bottom and a vertical slit between them. Correct removal suggestions would be great. Thanks guys.
2014 911 GT3 1979 930 Turbo 1970 911T 2016 Cayman 2019 Macan |
one of gods prototypes
the 4 holes on the radio (2 left/2 right) have retaining clips in them
cut a coat hanger into 2 small u's and stick on in on the left/right...... apply pressure sideways outward from center on both and then reach under and push from the rear.....the clips are about 3/4" in the hole..... then it'll slide right out.
Brought to you by Carl's Jr. |
