-   -   What size wheel spacers? (http://forums.pelicanparts.com/porsche-911-technical-forum/132227-what-size-wheel-spacers.html)
bkrygier 10-19-2003 03:49 PM
I finally got a set of fuch"s my tire size's are255/55 16 and 225/50 16. What would be the best size wheel spacer to put on to fill the wheel well better?
bk
Adam 10-19-2003 04:16 PM
It'll help if you can tell us what kind of 911 you're putting the wheels on.
Is it an SC/Carrera or turbo/widebody car?
bkrygier 10-19-2003 04:21 PM
Yes I guess it would sorry about that.
1983 sc cab.
Eric Coffey 10-19-2003 05:23 PM
EDIT: Just noticed your tire sizes. What are the wheel sizes? From the tire sizes listed, I assume they are 7's & 8's or 7's & 9's. If that is the case, then you shouldn't need any spacers! If they are 16x6's&7's, then you are running tires that are too big (should be 205's & 225's). Even on a 9" Fuchs, 255 is pushing it. With 6's & 7's (and correct tire sizes), you should be able to go up to 28mm on the rears, with modest camber and ride height (say, -1.5 and 24.75" fender height) without rolling the lips and/or rubbing issues. You can probably run 32mm+ if you are running around -1.8+ negative camber. As far as the fronts go, you can get away with a 7-8mm spacer between the hub and rim. If you go any larger, you will need longer studs. ;)
Jack Olsen 10-19-2003 05:44 PM
If you're running 225/255 tires, then I'd assume you have 8-inch (or 9-inch) rear wheels, and probably 7-inchers in front. I don't see why you would need (or possibly fit) spacers with that combo.
What size Fuchs did you get?
HotPorsche 10-19-2003 05:50 PM
BK .... Please let me know what spacers you go with as I am looking at doing the same. I have the factory 6/16 and 7/16 on my 84SC Targa Have you seen the spacers on E-Bay?
bkrygier 10-19-2003 06:11 PM
When I bought the car it came with 7&8 x16 bbs wheels with the 205/55 and 225/50 tires. Since then I purchased 6 & 7 x16 fuch's and put the same tires on the fuch''s. So should I have
205's & 225's instead? What will the oversize tires o ?
HotPorsche 10-19-2003 06:24 PM
BK ... I just looked at the engine compartment of my 84 Targa. The factory tires are 205-55-16 front and 225-50-16 rear. Sounds like you are in good shape.
bkrygier 10-19-2003 07:07 PM
thanks for the info I will let you know what I get
bk
